Material parameter value "Base_Emission" correct v
10 posts • Page 1 of 1
delle
Post by delle » Sat Sep 27, 2008 4:11 am
Hi, I'm trying to use the parameters "base_emission" and "emission" to simulate a TV set.
Which are the "physical correct values" for the spectrum?
I've used empirical values, but I prefer to use "phisical values".
Same question to simulate a neon tube (by emissive material), my next test. (e.g. a 32 watt linear neon tube) :roll:
Thank you
Delle
P.S. here is the "screen material":
<!-- Material : "_Mtl31 (5)" -->
<material>
<name>Material_7</name>
<diffuse>
<texture>
<!-- TextureMap[0] : "Mappa emissione" -->
<uv_set>default</uv_set>
<path>.\__Test Indigo Emission\CLP102_EMIS_RGB.bmp</path>
<exponent>2.2</exponent>
<b>1</b>
</texture>
<albedo>
<constant>
<rgb>
<rgb>0.572549 0.572549 0.572549</rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</albedo>
<base_emission>
<constant>
<rgb>
<rgb>2705.882490 2705.882490 2705.882490</rgb>
<gamma>2.2</gamma>
</rgb>
</constant>
</base_emission>
<emission>
<texture>
</texture>
</emission>
</diffuse>
</material>
Test emission map.png (235.75 KiB) Viewed 9406 times
Post by pixie » Sat Sep 27, 2008 4:27 am
The tv on the left should be more inclined towards the wall...
Bogey Jammer
Post by Bogey Jammer » Sat Sep 27, 2008 4:31 am
For fluorescent lamps some spectrum charts are available on the net and manufacturer documentations, just gogole them.
For tv image, I don't know, spectrum values may depend on the displaying image.
Indigo 1.1.11 32bit + Blendigo 1.1.7
My render supercomputer:
  • Acer aspire 5612Zwlmi
  • Intel T2060 dual core 1.6 GHz
  • 1GB RAM
  • vista home premium 32bit
Post by CTZn » Sat Sep 27, 2008 4:45 am
delle, please use the Code tag in post for materials, actually reading them is a bit of a nightmare, it's so better with identation...
You should put a reference surface in your scene, the floor doesn't help for evaluation, I would use 50% gray diffuse instead. Maybe put a sphere in front of them, of the same material. For now I have the feeling that they are weak, but if you use reinhard tonemapping, my evaluation could be biased by a low ior, dark floor :)
Put a physical light nearby so you have a referential for comparison, or render it separately, given that both images would be using the same linear or camera tm settings, and environment material.
Post by pixie » Sat Sep 27, 2008 5:08 am
The overall picture is nice, what is the problem?
Post by CTZn » Sat Sep 27, 2008 6:53 am
Calibration !? delle is seeking for correct tv emission v... alues :)
delle
Post by delle » Sat Sep 27, 2008 10:07 pm
Exactly, I've used Povray for years, I don't want to simulate reality (like Povray does) I want to render a scene closest to reality as possible I can.
Delle
Post by pixie » Sun Sep 28, 2008 12:44 am
Use your eyes then... ;)
Bogey Jammer
Post by Bogey Jammer » Sun Sep 28, 2008 6:08 am
If delle wants to work with spectrum, it would mean that he's hardcore enough to not be satisfied to work with his eyes only.
I quite understand him about fluo tubes, and know that real reproducing tv is problematic.
However I found this which contains a spectrum chart of phosphore light of an early tv set, and it seems that this was not so complex, modern screens are probably better and easier to render in Indigo than I expected.
  • 1GB RAM
Post by pixie » Sun Sep 28, 2008 6:41 am
So he want's to pick rgb values of images, which means which they mean and translate it to phosphor light, all the best for him then... meanwhile he might as well model those dots and separate the colors... just for the sake of being real :D
