Test with the Ivy generator
Olis
Post by Olis » Tue Jun 19, 2007 11:21 pm
I played around with the ivy generator this morning because I wanted to render something in indigo, and I made this scene.
Display took 1.08589s
Time elapsed: 2h, 18m, 5s
Done 962030000.00000 samples (2004.22917 samples per pixel)
116113.42876 samples / second (8.61227 micro-seconds / sample)
ivy tonemapped.jpg (114.75 KiB) Viewed 4873 times
Post by OnoSendai » Tue Jun 19, 2007 11:28 pm
Great!
bit much DOF effect tho, and I think the leaves are upside down?
matsta
Post by matsta » Wed Jun 20, 2007 3:55 am
hey man
great work, how did you handle the export of the scene... its obviously blender but whenever i made even slightly detailed ivy entanglments blender through out mem issuues on export. also when i tried to render just a bit of ivy using blendigo, it didnt pick up my alibedo's gave an error once indigo ran.
did yu have any of these problems?
if so how did you overcome them?
greetz
mat
dougal2
Post by dougal2 » Wed Jun 20, 2007 6:07 am
DOF would be OK if the focus was near the front/middle of the image, not at the back.
Olis
Post by Olis » Wed Jun 20, 2007 7:06 am
@ Ono: Yeah, you're right about the leaves. I didn't notice that.
@ Matsta: The export of the scene went flawless but when indigo started building trees I thought for a while that it was going to crash. It took up 1.94Gb of my swap file and almost hit the ceiling of it. I had no problem with the leaf material. I had made tests with a leaf material previously.
rendered with hybrid mode and bidir on
leaf test 1.png (470.22 KiB) Viewed 4753 times
rendered with hybrid mode and bidir off
leaf test 2.png (581.9 KiB) Viewed 4753 times
Kosmokrator
Post by Kosmokrator » Wed Jun 20, 2007 7:41 am
niiiice!!!
Dacksoldier
Post by Dacksoldier » Wed Jun 20, 2007 8:15 am
ok so if my computer si runnig out of memeory would increasing the swap space help me render the scene cuz i am trying render my car and when indigo loads the scene it quits with a runtime error saying not enough memory
Olis
Post by Olis » Wed Jun 20, 2007 10:35 am
Dacksoldier wrote:ok so if my computer si runnig out of memeory would increasing the swap space help me render the scene cuz i am trying render my car and when indigo loads the scene it quits with a runtime error saying not enough memory
Yeah, try to increase the swap file, that might help :wink:
Olis
Post by Olis » Wed Jun 20, 2007 10:55 am
This is what it looks like when I am exporting. You can see it decrease by the end.
It's a close call
swap file.PNG (281.47 KiB) Viewed 4684 times
Sebastian
Post by Sebastian » Wed Jun 20, 2007 11:27 pm
Hmm, if there's a Problem with the RAM I can render it for you on 2GbRAM on 2 1,5GhZ Dual Core =Ghz ... PC's (perhaps I can get a third one ^^ 2,4GhzDual 2GbRAM) ^^.
Olis
Post by Olis » Thu Jun 21, 2007 2:45 am
I rendered another one with slight modifications. The leaves are not upside down anymore and it's higher res :D
Display took 10.19310s
Time elapsed: 12h, 26m, 22s
Done 4748330000.00000 samples (2473.08854 samples per pixel)
106030.82838 samples / second (9.43122 micro-seconds / sample)
ivy test 2.jpg (367.81 KiB) Viewed 4578 times
Post by OnoSendai » Thu Jun 21, 2007 2:55 am
cool :)
Post by CTZn » Thu Jun 21, 2007 4:54 am
Yes it is.
SURFiNG
Post by SURFiNG » Thu Jun 21, 2007 6:51 am
Is it normal that if i launch IVY on over a blender exported (with triangulate) simple scene and add just a small with no many branches generation, IVY hangs for hours consuming CPU and "not responding" ???
Im using VISTA HOME with ATI x1650 Card
Im asking here because i love you all
Olis
Post by Olis » Thu Jun 21, 2007 8:10 am
What matters more is what processor you have.
