Alami Rendering Thread
Re: Alami Rendering Thread
And now this:
by Alamy » Thu Jul 22, 2021 7:20 pm » in Finished Artwork
What happeens here?
Somebody can explain to me?
What happeens here?
Now this, I paste and copy...
I´m crazy?
I´m crazy?
Again, this is the last, or no...
Is a witch question?
I think this is little bit strange.
Post by Alamy » Fri Jul 23, 2021 6:20 am
this was the date of my first post.
and this is my join date to the forum
Alamy
I only have 71 posts
Alamy
Seems that tere are rats in the forum!
Excuses for my bad language some times. Is very recent.
I´m excited to help you, don´t doubt it!
Now all the dates of my posts change...
Definetly I´m crazy and I don´t see well...
Or Somebady have acces to my accounts and this forum?
Is the pentagono? Cia? Fbi? Vacatione?
Am I persecuted?
Sorry for dirt your clean thread, really strange... Cada vez es más descarado... Te compensaré con ambiente y volumetría, aunque puede que tus clientes sólo quieran GPU.
I can´t work with a pigs! I need the scene or you must do it by yourself!
Am I persecuted?
Ok, I will post screen shots to show you the problem I'm facing right now with Exit portals
Exit portals is not a good solution. Every time you reduce the accurancy of Indigo is a bad decision.
Exit portals don´t work well since too many time ago! But ONO explained some progresses don´t materialized some time ago.
What is the problem of render a overnight in MLT bidirectional mode with yhe pmoney that you earn with your work?
Is necesary to run so fast (two minutes)?
You don´t model the furniture, only the envelope of the rooms!
To play "saloncitos de pin y pon" is an easy way to get a life!
For me is impossible at the moment... even when I´m able to do it better than nobody else! (Or almost good).
I'm not using the exit portals to render fast, I'm just expermint with exit portals how to make the scene not to look dark in some areas, the Image that you see already doesn't have exit portals
this one has exit portal
but when I add the plane with material and assign exit portal for this material, the window behind this exit portal dissappear, I don't want to use exit portal, but I'm curios how to make this work for my info.
"the window behind this exit portal dissappear"
Now I see your skills...
Try to put the portal behind the window.
Don´t woorry, is a principiant fail . Even when Indigo is the simpliest program to this kind of workflow, sometimes is easy to make a mistake...
330 views in 15 hours, impressive...
Put the exit portal in the outside of your room,
