by suvakas » Wed Aug 08, 2007 2:11 am
luqui82 wrote:Can you post the model on .3ds or .skp format? I want to try to render it with Skindigo.
Thanks in advance
Can Sketchup import obj format?
I think it doesn't fit into 3ds. It was over 70k polys, if i remember correctly. Will check when i get home.
luqui82
by luqui82 » Wed Aug 08, 2007 2:18 am
yes, there´s a plugin that can import obj files into sketchup.
thank you
crc
by crc » Wed Aug 08, 2007 5:00 am
suvakas wrote:I use 3ds Max.
No multiple scenes output or something like that. Animation is build into Max exporter. It exports a new frame as soon as the previous frame gets done. Everything is automatic and igs scene requires the same amount of disk space as for still image rendering.
Finally I used VirtualDub to render the png files into *.avi
So all you need for doing animations in Max is a fast cpu - which i don't have
by suvakas » Wed Aug 08, 2007 7:36 am
@luqui82
Here is the model for you in obj format.
There are some f***ed up vertexes though. I have no idea from where those came from. But maybe you can still use it.
- greeble.zip
- (2.75 MiB) Downloaded 176 times
by suvakas » Wed Aug 08, 2007 7:40 am
Kram1032 wrote:
Did you also use exit portals?
Sry, missed your question before.
Yeah, there is an exit portal on the window opening. Scene is lit by blue background color.
by Kram1032 » Wed Aug 08, 2007 10:09 am
ah I see
funny - doesn't look that blue^^
CoolColJ
by CoolColJ » Wed Aug 08, 2007 10:58 am
I'll play around with the model myself as well
SmartDen
by SmartDen » Mon Aug 13, 2007 7:50 pm
Can you please explain how did you rendered png sequence to avi with VirtualDub.
by suvakas » Mon Aug 13, 2007 9:21 pm
I used VirtualDub Mod v 1.5.10 (standard veresion doesn't support png i think)
You can get it from here:
http://virtualdubmod.sourceforge.net/
png filenames must contain framenumbers. They should be in correct sequence. Then you just open the first frame (in my case greeble_frame_0000.png) and all the other frames are loaded automatically. After that it's just a mather of picking the codec and saving as avi. You can also change the frame rate under video/frame rate... I used 25 cause mine was done using PAL format in Max
SmartDen
by SmartDen » Tue Aug 14, 2007 1:24 am
Thanks a lot, suvakas!
BTW new version of VirtualDub 1.6.19 also supports png and works very fine!
by suvakas » Tue Aug 14, 2007 1:35 am
SmartDen wrote:Thanks a lot, suvakas!
Really? Cool. I havn't checked if there is a new version for a very long time.
sciman
by sciman » Wed Sep 12, 2007 1:37 pm
What did you use to open each igs file, render it, and then move on to the next??
by Whaat » Fri Sep 14, 2007 3:28 am
sciman wrote:What did you use to open each igs file, render it, and then move on to the next??
BUMP for this question. C'mon suvakas...do tell.
by suvakas » Fri Sep 14, 2007 3:39 am
Whaat wrote:sciman wrote:What did you use to open each igs file, render it, and then move on to the next??
There are no multiple igs files. Only one.
I'm checking from maxscript if Indigo is running and if it is not, then I'm exporting a new frame + I add a frame number to output image name. That's it.
Users browsing this forum: No registered users and 126 guests
