Motion Blur Implementation
How about some info on implementing motion blur? I thought I read that Ono emailed some stuff to fused. Can someone please explain the XML tags related to motion blur?
Re: Motion Blur Implementation
Check out motion_blur_test.igs and camera_motion_blur_test.igs from the testscenes dir in Indigo 2.0.4.
Ono,
is the intent of the rotation quaternion element to represent the current orientation or the change in orientation from the previous keyframe? It seems to represent a change...
It describes a rotation transformation, applied after any <rotation> element transformation if present.
So it's not relative to the last keyframe.
so what if you don't have a <rotation> element present?OnoSendai wrote:It describes a rotation transformation, applied after any <rotation> element transformation if present.
OK. Could someone just spell it out for me?
I would like to see actual code that does the following:
Given vectors for the x,y,z axes of a model, convert to the type of quaternion that is accepted by Indigo. I know I am on the right track but I need a bit of help here.
I'll ask Nick tomorrow and get back to you.
Dont be confused by the word "quaternion", it just expects simple axis rotation that is internally converted to a quaternion. i implemented 3 different ways to convert it and never got correct results, then asked nick and he told me that.Whaat wrote:OK. Could someone just spell it out for me?I would like to see actual code that does the following:
i think the easiest is that the <rotation> just carries an identity matrix (maybe with scale) when using motion blur.
heres some of my (experimental) motion blur code:
[...bleh...]
//SCALE
SceneExportRealValue("scale", 1.0, model);
//MESH_NAME
SceneExportStringValue("mesh_name", meshname.GetFileString(), model);
//Motion blur
Real strength = 1.0;
LONG num_keyframes_inbetween = 0;
if (ObjectHasMotionBlurTag(obj, strength, num_keyframes_inbetween)) {
//experimental mb stuff
SceneExportMoBlurMatrix(model, m); //exports the identity matrix with applied scale
LONG fps = mDoc->GetFps();
BaseTime time = BaseTime(m_frame, fps);
//get topmost object with animation, neccecary so all childs will be correctly animated
//if found, animate
BaseObject *topmost = GetTopmostAnimated(obj);
if (topmost) mDoc->AnimateObject(topmost, time, ANIMATE_QUICK);
Real rotation;
Vector axis;
Vector position;
position = obj->GetMg().off;
MatrixToRotAxis(obj->GetMg(), &axis, &rotation);
SceneExportKeyframe(0.0, model, rotation, axis, position); //exports the first keyframe
//some stuff to get along with c4d animation stuff. only whole keyframes can be
//exported for now - getting values inbetween is a bit tricky
Real m_exposure = 0.3333333;
Real newFrame = (Real)m_frame + (fps * m_exposure);
Real step = 1 / Floor((fps * m_exposure) + 0.5);
//export all other keyframes
for (int i = m_frame+1; i < newFrame-0.5; i++)
time = BaseTime(i, mDoc->GetFps());
SceneExportKeyframe(step*i, model, rotation, axis, position);
time = BaseTime(newFrame, mDoc->GetFps());
SceneExportKeyframe(1.0, model, rotation, axis, position);
} else { //if no motion blur, normal rotation
//POS/ROTATION/SCALE
SceneExportPosAndMatrix(model, m);
}Re: Motion Blur Implementation
I think the part I am interested in the most is this:
Do you mind exposing this method?
Or is part of the API?
MatrixToRotAxis(obj->GetMg(), &axis, &rotation);Re: Motion Blur Implementation
Its part of the API, but no problem
you can clearly see that maxons coders dont give a damn about writing english comments
probably copyrighted by maxon or so, so make sure you dont copy that 1:1. be inspired
added some translation for you...
void MatrixToRotAxis(const Matrix &mm, Vector *v, Real *w)
Matrix m = mm;
// MatrixVectoren MUESSEN normiert sein!!! ---vec's must be normalized
m.v1=!m.v1;
m.v2=!m.v2;
m.v3=!m.v3;
// Winkel berechnen ---calculate angles
*w = ACos((m.v1.x+m.v2.y+m.v3.z-1.0)/2.0);
// Achse berechnen ---calc axis
v->x= m.v2.z-m.v3.y;
v->y= m.v3.x-m.v1.z;
v->z= m.v1.y-m.v2.x;
*v = !(*v);
if (*v==0.0)
*v = Vector(0.0,1.0,0.0);
*w = 0.0;
}probably copyrighted by maxon or so, so make sure you dont copy that 1:1. be inspired
