Indigo 1.1.1
Post by CTZn » Sat May 31, 2008 3:52 pm
I am still fuzzy on what happens to two vertices with the same position and normal but with different UV coordinates.
They use very probably a different value for displacement = ripped apart in the direction of the normal.
Sounds the reverse of what we want, huh ?
Maybe merging UVs would make more sense (or that's what you are talking about) ? I'm still not sure :)
Post by Whaat » Sat May 31, 2008 5:47 pm
I've been testing out the new procedural fractal stuff. This is the usual type of output that I get. It seems like there is a bug with the procedural code related to the uv coordinates.
In the one image, FBM is applied to the diffuse texture.
In the other image, a diffuse texture is applied to the same geometry using the same uv coordinates.
default.zip
IGS file
(1.68 KiB) Downloaded 262 times
Post by Whaat » Sat May 31, 2008 6:20 pm
Another issue that I don't think has been mentioned:
normal smoothing doesn't seem to work at all. I assume it has been disabled. Is this permanent?
Post by suvakas » Sat May 31, 2008 8:00 pm
OnoSendai wrote:Hi,
I'm thinking of a new mesh description format like this...
What about 3ds and obj formats? xml embedded meshes are rarely used in Max these days. They are slow (because maxsccript is not C) and the poly count is also limited. :roll:
[edit]
@Whaat
The smoothing issue is know and (i may be wrong) occures on those "bad meshes" that have dupli verts?
Post by fused » Sat May 31, 2008 8:20 pm
ya, what about obj format? i always tried to keep away from it, becaues of the size of the files when having really large meshs. (obj tends to be smaller, especially obtimized obj)
dougal2
Post by dougal2 » Sat May 31, 2008 10:42 pm
MtI Exports to OBJ, it's about the only option at present. The only drawbacks that I experience are I think to do with bugs in the Maya OBJExporter plugin :roll:
Also, I'm not sure if OBJ supports multiple UV sets.
Post by CTZn » Sun Jun 01, 2008 1:32 am
It does. You just have to be aware that all indexes start at 1, not 0. I couldn't find the mention of a limit for material definitions, vertex textures (uv maps) or anything else, from various sources.
Download here the most complete I found (link to download page, zipped pdf). Here a simpler one (txt, less data).
Amongst other unused features, the obj format can hold:
Free-form curve/surface attributes
Five types of free-form geometry are available in the .obj file
format:
o Bezier
o basis matrix
o B-spline
o Cardinal
o Taylor
These being rational or not.
I love the obj format :D
Post by OnoSendai » Sun Jun 01, 2008 1:38 am
I don't think OBJ supports multiple uv sets.
Post by CTZn » Sun Jun 01, 2008 1:53 am
Mmh that's right, I tried with Maya. That's why they don't mention a limit.
*argh*
Post by OnoSendai » Sun Jun 01, 2008 1:58 am
fused wrote:ya, what about obj format? i always tried to keep away from it, becaues of the size of the files when having really large meshs. (obj tends to be smaller, especially obtimized obj)
What about .obj format?
Post by OnoSendai » Sun Jun 01, 2008 2:01 am
Actually.. I might drop normals altogether from the embedded mesh (embedded_2) definition, and just compute the shading normals in Indigo.
Post by CTZn » Sun Jun 01, 2008 2:13 am
Is that irony, Ono, when you just atomized a pure child's (me) dream ? :cry: Well obj can refere to multiple materials, maybe one ould hack that by evaluating one material (eg including texture)
    g front
    usemtl red
    f 1 2 3 4
when a grouping (g) statement occurs. Because i believe it's ok to redefine already defined faces, I mean appending
    g front
    usemtl blue
    f 1 2 3 4
after the previous code should be ok. Dunno if that hack can really be implemented, but if yes then you can set as many textures than materials to a single face (within the same uv space off course).
I hope that makes sense at least...
fused wrote:It seems like there is a bug with the procedural code related to the uv coordinates.
That could be right, but are you sure the UVs are between 0 and 1 ? They can be higher in many cases, and maybe Indigo can't manage procs above the 1 coord ?
Post by fused » Sun Jun 01, 2008 7:07 am
:? :lol:
spotted an error:
"i always tried to keep away from it". i dont mean obj format, i tried to keep away from embedded.
but still, i dont really know what you want :P
Post by OnoSendai » Sun Jun 01, 2008 5:52 pm
Ok...
here's what I'm thinking for the new embedded mesh format.
<mesh>
		<name>mesh2</name>
		<normal_smoothing>true</normal_smoothing>
		<embedded_2>
			<expose_uv_set>
				<index>0</index>
				<name>albedo</name>
			</expose_uv_set>
			<v p="-1.5 0 0" />
			<v p="-1.5 0 2" />
			<v p="1.5 0 2" />
			<v p="1.5 0 0" />
			<v p="-1.5 0 0" />
			<uvs uv0="0 0" uv1="0 0" />
			<uvs uv0="0 1" uv1="0 100" />
			<uvs uv0="1 0" uv1="100 0" />
			<uvs uv0="1 1" uv1="100 100" />
			<triangle_set>
				<material_name>mat1</material_name>
				<t v="0 2 1" uv="0 2 1" />
				<t v="4 3 2" uv="0 3 2" />
			</triangle_set>
		</embedded_2>
	</mesh>
Shading normals will be computed internally by Indigo.
Spatially adjacent triangles should index the same two vertices for the shared edge, if and only if the surface is supposed to be C1 continuous over the edge. If there is supposed to be a crease, then the edge vertices should be duplicated, and each triangle should index different vertices.
Makes sense? Thoughts?
Exporter writers: do you think you can export your meshes in such a format?
filippo
Post by filippo » Sun Jun 01, 2008 6:06 pm
wonderfull new features....
filippo
