How to make illuminated textures (blendigo)
This is my first attempt at a tutorial and it's in pdf format (sorry). I used my illuminated advert to illustrate how to get around the problem of light emitting textures. It's not ideal for every situation, but it sure works. The tutorial requires blendigo but I'm sure the material methods are suitable for all indigo users.
- brightads_tutorial.zip
- (3.81 MiB) Downloaded 1355 times
@carnivore.
Try it without SSS and see what happens.
it makes no difference. Uniform SSS is just RGB SSS with R, G, and B all at the same value. With RGB SSS you can control the colour of the scattering. That is the only difference.
No problem, Nick. I will look at the Wiki if you like to see if I can put this in the right format.
Ok, then, ermm..., I WANTED to use coloured sssmrCarnivore wrote:It DOES make a difference. rgb sss with same colours takes WAY longer than uniform sss!
I just tried this tutorial, very nice, thank you.
but I just get a black image !
Blender 2.45
Indigo 1.0.5
Blendigo 1.0.4
I cant get the blend material (poster+clear) to let any light through !
if I remove the 'poster', I do get light
(I checked the normal of the light obj, it points 'outside' the enclosure)
if I place a light source outside, I do see the poster..
I tried using 'null' material for 2nd blend value ..
in this case, I dont see the image at all...
any hints ?
thx
Philippe
Blender 2.45
Indigo 1.0.5
Blendigo 1.0.4
any hints ?
thx
Philippe
