Glass test
6 posts • Page 1 of 1
tarikb
Glass test
Post by tarikb » Mon Nov 16, 2015 1:21 am
Same scene diferent glass, rendered 7min, Bdr path tracing..
Skindigo
tarikb
Re: Glass test
Post by tarikb » Mon Nov 16, 2015 1:24 am
Glass material set up
Skindigo
Re: Glass test
Post by Oscar J » Mon Nov 16, 2015 1:47 am
Yeah, no surprises here. :)
Re: Glass test
Post by Pibuz » Tue Nov 17, 2015 4:34 am
To render efficient FLAT window panes, the only solution is arch glass indeed. Fast and issue-less.
What I would expect, though, is that the other kind of glass would render slower but correctly.
Instead it seems that either you set it arch glass or you won't get a decent result in reasonable render times.. :?
tarikb
Re: Glass test
Post by tarikb » Wed Dec 16, 2015 8:33 am
As technology is the fastest developing part of society, in a year or two, it won't be question which glass to use in render, and every render program will be unbased, because comp speed will not be the problem :) That's one of the reason for me to use indigo as default render program :)
Skindigo
Re: Glass test
Post by Oscar J » Wed Dec 16, 2015 9:17 am
Pibuz: they're all pretty much correct. Keep in mind that the first glass type from Saint-godain has dispersion, which is why it's so much slower to render. The other ones are just, as you said, slower. 7 minutes is not much, especially on an i5 processor.
Users browsing this forum: No registered users and 87 guests
