Ferrrari 458 Italia
12 posts • Page 1 of 1
contegufo
Ferrrari 458 Italia
Post by contegufo » Wed Sep 23, 2015 4:47 am
Hi
Some modest examples of rendering.
The model is challenging and the hardware is not up to the task then also scenes hide the inability of the writer.
The body is not as I would like and it is taken from the online database.
I have big problems with front and rear lights that I believe are among the most difficult things.
Even the glasses I wish I was more reflective.
If you load a standalone environment map in the application software is closed. I think it's a problem because the operating system before the upgrade did not happen.
All tips are welcome.
Re: Ferrrari 458 Italia
Post by Oscar J » Wed Sep 23, 2015 6:27 am
The glass and carpaint don't need to be more reflective, the just need something to reflect. Use an environment map, and try loading it into the Cinema 4D exporter.
I also get crashes when loading stuff from my local disk in Max OS X, it crashes under QT Core or something like that. Definitely something for the devs to look into, although I think they're already aware of the issue.
What problems do you have with your front and rear lights?
contegufo
Post by contegufo » Thu Sep 24, 2015 4:11 am
Hi
I believe that the shader carpaint is not suitable for a red Ferrari (RGB 204,0,0) so I changed.
The problem of the rear lights is that they are two objects one inside the other. The inner one is chrome wrapped by red plastic.
Application stanalone I managed but there are big problems in Cinema also because of the preview that is very slow.
Post by Oscar J » Thu Sep 24, 2015 4:39 am
Pretty nice rear lights! :)
contegufo
Post by contegufo » Thu Sep 24, 2015 6:50 am
Hi
The miracles of Indigo.
This is the partial result after only 4min. (1280x720 px)!
I think it takes an area ligth on the front.
Work in progress......
contegufo
Post by contegufo » Wed Oct 07, 2015 11:31 am
Hi
Final rendering.
Post by Oscar J » Thu Oct 08, 2015 5:57 am
Your tires look just gorgeous in some of those pics. But a more interesting environment would certainly help to make the images more interesting.
contegufo
Post by contegufo » Thu Oct 08, 2015 6:21 am
Hi
Thank you, unfortunately I have trouble finding adequate maps for a composition!
contegufo
Post by contegufo » Fri Oct 09, 2015 2:55 am
Hi
Test floor.
contegufo
Post by contegufo » Fri Oct 09, 2015 10:33 am
Hi
Thanks for the suggestions!
:D
