[REQ] Environ map/Sun
11 posts • Page 1 of 1
Doug Armand
Post by Doug Armand » Sun Jan 22, 2012 7:19 pm
Simple request - can we have the option to use both the Sun and an environment map at the same time?
I have been playing around with Sketchup/Skindigo recently purely because I found out that you can do this with that combo so we know it can be done :wink:
Would be so helpful in setting up realistic outdoor scenes.
Doug
Doug Armand
ninopiamonte
Re: [REQ] Environ map/Sun
Post by ninopiamonte » Sun Jan 22, 2012 8:32 pm
yeah, me too.
I use Sketchup and i'd like also to have that combination
of Environment Map + Sun....
...................................hope they add it to next release.
dougal2
Post by dougal2 » Mon Jan 23, 2012 1:40 am
I'm planning to overhaul the lighting options so that you can easily mix different sources, but I'm hoping Glare can fix one or two related bugs in Indigo itself first. But even if they don't, I'll be looking at this very issue this week anyway.
Doug Armand
Post by Doug Armand » Mon Jan 23, 2012 1:55 am
Thats brilliant Dougal - can't wait and thanks for the quick response
Doug
Doug Armand
dougal2
Post by dougal2 » Tue Jan 24, 2012 6:34 am
I've got something that pretty much works here, but still need more testing to make sure no features are lost in the reshuffle.
Doug Armand
Post by Doug Armand » Tue Jan 24, 2012 7:48 am
Looking interesting - when can we 'test' it? :wink:
Doug
Doug Armand
galinette
Post by galinette » Tue Jan 24, 2012 8:55 am
Hello,
Is the XML code for adding two environments (sun+envmap) documented somewhere?
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
dougal2
Post by dougal2 » Tue Jan 24, 2012 10:44 am
galinette wrote:Hello,
Etienne
Not very well, I had to download an older version of Indigo (1.1.18) to get the old example scene background_material_test.igs and I also found a forum thread explaining the <sum> material.
There are two issues with this in 3.2.5 currently though:
1. The new captured-simulation for sunsky isn't recognised when used as a background material (render won't start with "unknown element Model in Sunsky" error)
2. Light layer assignments don't work properly
At the risk of thinning the documentation even more, my self-made reference looks like this:
	<material>
		<name>background_exr_A</name>
		<diffuse>
			<texture>
				<path>E:\RenderStuff\HDR\Dosch Industrial 2\EXR-SX\INDREF-001SX.exr</path>
				<exponent>1.0</exponent>
				<tex_coord_generation>
					<spherical>
						<rotation>
							<axis_rotation>
								<axis>0 0 1</axis>
								<angle>1.6</angle>
							</axis_rotation>
						</rotation>
					</spherical>
				</tex_coord_generation>
			</texture>
			<base_emission>
				<constant>
					<uniform><value>1.0</value></uniform>
				</constant>
			</base_emission>
			<emission>
				<texture>
				</texture>
			</emission>
			<layer>0</layer>
		</diffuse>
	</material>
	<material>
		<name>SunShapeA</name>
		<sunsky>
			<sundir>-0.5 -0.5 0.7071067812</sundir>
			<turbidity>2</turbidity>
			<sun_layer>1</sun_layer>
			<sky_layer>2</sky_layer>
		</sunsky>
	</material>
	<material>
		<name>BGConst</name>
		<diffuse>
			<albedo_spectrum>
				<uniform><value>0</value></uniform>
			</albedo_spectrum>
			<base_emission>
				<constant>
					<rgb>
						<rgb>0.8 0.2 0.8</rgb>
						<gamma>1.0</gamma>
					</rgb>
				</constant>
			</base_emission>
			<layer>3</layer>
		</diffuse>
	</material>
	<background_settings>
		<background_material>
			<material>
				<name>background_material</name>
				<sum>
					<mat>
						<mat_name>background_exr_A</mat_name>
						<weight><constant>1</constant></weight>
					</mat>
					<mat>
						<mat_name>SunShapeA</mat_name>
					</mat>
					<mat>
						<mat_name>BGConst</mat_name>
					</mat>
				</sum>
			</material>
		</background_material>
	</background_settings>
Doug Armand
Post by Doug Armand » Thu Feb 16, 2012 4:41 am
Any update on this Dougal - this would be a really useful feature for me.
Doug
Doug Armand
dougal2
Post by dougal2 » Thu Feb 16, 2012 5:46 am
It's already in the latest version. Just use a sun and hemi lamp at the same time.
Doug Armand
Post by Doug Armand » Thu Feb 16, 2012 6:40 pm
Wow so it is!. Took me a while to work it out but seems to be working fine - many thanks for that Dougal :D
Doug
Doug Armand
