Wanted: nice render with new Sun/Sky model
FakeShamus
Re: Wanted: nice render with new Sun/Sky model
Post by FakeShamus » Thu Dec 08, 2011 12:56 pm
here's what I've been playing with - not sure if it shows off the sky enough, but I could try some other angles.
but I definitely see the difference, new sky model is awesome!
FakeShamus
Post by FakeShamus » Thu Dec 08, 2011 1:48 pm
a couple variations:
FakeShamus
Post by FakeShamus » Thu Dec 08, 2011 2:26 pm
from another vantage point:
Doug Armand
Post by Doug Armand » Thu Dec 08, 2011 11:15 pm
some nice examples here but can I just say there is a lot of vignetting in most of them - is there still no option to manage this? of course if that is the effect you guys are after then just ignore :D
Doug
Doug Armand
Post by pixie » Thu Dec 08, 2011 11:23 pm
Doug Armand wrote:some nice examples here but can I just say there is a lot of vignetting in most of them - is there still no option to manage this? of course if that is the effect you guys are after then just ignore :D
Indeed there is, I use it all the time. :D
everwind
Post by everwind » Fri Dec 09, 2011 12:31 am
Well for me this is not vignetting at all. Vignetting is due to a lens and appears in every corner of picture. This is just difference of tones in the sky, which is 100% normal in a regular sky with such sky.
Ex from my personal photos : this is not vignetting : http://www.flickr.com/photos/didus-inep ... hotostream
This is vignetting : http://www.flickr.com/photos/didus-inep ... 6316339262
Doug Armand
Post by Doug Armand » Fri Dec 09, 2011 12:39 am
You say potato - I say potato but I think you still knew what I meant right? sheesh :evil:
Doug
Doug Armand
galinette
Post by galinette » Fri Dec 09, 2011 1:35 am
Indeed Indigo has some vignetting exactly as a lens does. More precisely, it used to be mandatory and not configurable, and since a few versions it has the option of not vignetting. This vignetting in Indigo is due to a geometric effect and is one of the many reasons why a real lens may have vignetting.
Just render a pure white envmap with no geometry and a wide angle lens setting, and you will see what I mean...
Eclat-Digital Research
http://www.eclat-digital.com
galinette
Post by galinette » Fri Dec 09, 2011 1:36 am
Just render a pure white envmap with no geometry and a wide angle lens setting (and the new option to not vignet turned off), and you will see what I mean...
haluperido
Post by haluperido » Mon Dec 12, 2011 2:25 pm
galinette wrote:Animating time of the day over these scenes would be very nice!
Etienne
I've made something like this with my Stonehange scene: http://youtu.be/Cs-rDC1gw4k
dougal2
Post by dougal2 » Tue Dec 13, 2011 12:02 am
Etienne
Amazing !
Post by lycium » Tue Dec 13, 2011 12:27 am
Etienne
Awesome animation! 8)
Post by zeitmeister » Tue Dec 13, 2011 12:51 am
:shock:
Post by CTZn » Tue Dec 13, 2011 2:37 am
Really astounding scene, nice work !
At the risk of sounding harsh however, I regret that aperture diffraction was not used but it would probably have been too costly for the few really concerned frames (those featuring sun captures).
haluperido
Post by haluperido » Tue Dec 13, 2011 8:59 am
Hi Guys!
Glad you like this anim :)
CTZn, I've been actually trying to render it with aperture diffraction (AD Post Process) turned on, but for some reason I couldn't achieve desired quality/render speed with it. It caused overall bluriness of the image (look at the first images I've posted in this thread [I've removed fireflies in photoshop and adjusted the sharpness as well but it still looks somewhat blurry]), huge amount of fireflies and really weird huge reddish circular artifacts at certain sun angle (sun near horizon, camera just above the ground).
I think it might be due to the size of the scene (ground plane size is 290x230m) and high reflectivity of grass
(60% Phong component with ior 10 mixed with blend of diffuse transmiter and phong ior 3.0), cause fireflies didn't show up with diffuse material set for the grass. I didn't try to downscale the scene and it's my first scene that big, so not really sure how the scale is affecting final image.
I've tried with physical diffraction as well, and it looked quite good, but than again had to use Path Tracing with MLT what resulted in really long rendering time to achieve clear sky without noise and diffraction effect was still unsatisfying.
Anyway the scene needs couple more fixes so I'm still playing with it and maybe will render it again when I'll get some more idle CPU time ;)
Users browsing this forum: No registered users and 64 guests
