Page 1 of 1
Management of materials
Posted: Tue Feb 19, 2008 5:01 am
by metapixel
Hi, maybe this can be useful link to the management of materials,
I like very much!
Http://www.nodejoe.com
Posted: Tue Feb 19, 2008 5:14 am
by psor
Thanx for posting. I tried it in the past and yes it's cool but had some
nasty bugs that could crash 3dsmax. So watch out if you do serious
work. ;o))
take care
psor
Posted: Tue Feb 19, 2008 6:03 am
by sth
isn't it offtop?
Posted: Tue Feb 19, 2008 6:05 am
by psor
sth
psor
Posted: Tue Feb 19, 2008 6:09 am
by sth
It's all good! ;)
Posted: Tue Feb 19, 2008 6:17 am
by psor
sth
psor
Posted: Tue Feb 19, 2008 6:23 am
by sth
thanks for this support... now feeling a bit better with my waiting....
Posted: Tue Feb 19, 2008 6:26 am
by psor
Ya, what to do mate?! What do you need the update for? The actual
version works quite well, no? There are just a few things missing
and some bugs. I'm sure that suvakas will find some time this year
to update it.
take care
psor
Posted: Tue Feb 19, 2008 6:49 am
by suvakas
Bugs? What bugs? Where?
Posted: Tue Feb 19, 2008 6:53 am
by sth
i.e. in psor's signature?
Posted: Tue Feb 19, 2008 7:07 am
by psor
@suvakas
I was going to bug you later with it 'cause I know you're busy. It has
to do how you export igm files. They can't be uploaded to the matDB
because of a syntax error:
<?xml version="1.0"?>
<scenedata>
</scenedata>
This is missing and in the igm specs it is needed to make the file
complete and working everywhere. Additionally I can't load igm
files into Maxigo, it's just doing nothing. I haven't spend much
time to figure out why. Some other bugs have to do with modifiers,
like displacement and the 'transformation error'. If I do scale
an object just a lil bit your export routine is not resetting/applying
the transformation right and I get an object/mesh that has the
wrong size when I do render. If you've time I can send you some
simple scenes to get the bugs out. But only if you've got time ...
take care
psor
Posted: Tue Feb 19, 2008 7:30 am
by suvakas
Oh, yes, thanks for reminding. Indeed, igm has <materialdata> instead of <scenedata>. This was the "previous standard". Will fix that.
There has been some strange stuff going on with ImportMat before, but i can't doublicate this. Currently it works fine on my system. If you find something, then let me know.
Yep, I don't have much time
, but you can still send me the bad scenes. I'd like to take a look at these.
The scale is evil in general. I suggest you to always use Xform modifier and scale the gizmo instead of scaling directly. I remember reading it on CgTalk forums, that when you use scale directly in node level, then you have a disaster waiting to happen
