Page 1 of 2
Indigo 0.9.6 Vs FryRender 1.8 demo(up-date)
Posted: Thu Aug 30, 2007 6:09 am
by filippo
Hi, I do a litle test to compare Indigo and fryrender on 3d studio max.
all the parameters are equal.
filippo
sorry for my poor language
render time 32 minutes on 2 x Intel Xeon quad
Posted: Thu Aug 30, 2007 6:17 am
by zsouthboy
Exit portals? (In both cases?)
Posted: Thu Aug 30, 2007 6:20 am
by filippo
yes...exit portal in both cases!!!....in 30 minutes..I post the maxwell image...
Posted: Thu Aug 30, 2007 6:23 am
by OnoSendai
I'm not sure your Fry exit portal is working.. seems pretty slow.
Posted: Thu Aug 30, 2007 6:54 am
by Kram1032
the light situation slightly changed...
Posted: Thu Aug 30, 2007 7:17 am
by vansan
No portals here, for sure!
Posted: Thu Aug 30, 2007 7:35 am
by tizxx
Ciao Filippo
Gli exit portal in FRYRENDER non sono dei semplici piani...
come è invece possibile inserire in Indigo Render...
Devi creare un parallelepipedo delle dimensioni del foro e fori di apertura gli togli una faccia inverti le normali, o fai in modo che puntino all'interno della stanza...
le 5 faccie del parallelepipedo devono restare fuori dal foro ed essere attaccate al foro stesso...
leggiti sto tutorial...
http://www.fryrender.com/sh_images/tuts ... ortals.pdf
ciao ciao
:lol:
TiZxx
Posted: Thu Aug 30, 2007 8:40 am
by filippo
I am rifaring rendering in Fryreder with exit portal on.
and I test the maxwell in the same scene...
filippo
Posted: Thu Aug 30, 2007 8:42 am
by filippo
tizxx wrote:Ciao Filippo
ciao ciao
:lol:
TiZxx
sto gia rifacendo il test con fryrender con l'exit portal acceso....
am already RIFARING the TEST in fryrender whit the exit portal on...
Posted: Thu Aug 30, 2007 8:45 am
by Kram1032
I think, your exit portal in indigo is too small! there is a pixel line, that rendered black ;)
Posted: Thu Aug 30, 2007 8:47 am
by filippo
Kram1032 wrote:the light situation slightly changed...
in the image of fryrender the exit portal it's off...sorry...
but the light situation it's the same......to set the direct light in Indigo as the sun in fryrender I have used my Indigo tutorial's(http://www.indigorenderer.com/joomla/fo ... php?t=1241)....but the result it is not the same...why?
when I finished the speed test I post all the scene....so you can se the sun parameters...
filippo
Posted: Thu Aug 30, 2007 8:59 am
by Kram1032
the sun comes from exactly the same position?
then, it might be, 'cause of bidir ;)
Posted: Thu Aug 30, 2007 9:12 am
by filippo
maxwell test in the same scene .
render time 32 minutes(all the image are renderer in the same workstation)
filippo
Posted: Thu Aug 30, 2007 9:16 am
by Kram1032
interesting.... the sky looks much brighter, in maxwell...
indigo's the best, I'd say :)
fry is rendering with most contrast, as far as I can judge it :)
Posted: Thu Aug 30, 2007 9:32 am
by vansan
Maxwell 1.5 and Fry beta1.8 sacrificed the sharpness of the render to speed up noise clearing.
Indigo is the best! :)
