Indigo Motion Blur (3dMax)
It does not work.
how motion blur works ?
- thesquirell
Re: Indigo Motion Blur (3dMax)
Hello! Nice to have you here!
Motion blur works in conjunction with lots of parameters, mainly related to the camera. What I can tell you with that scene you posted is that you have to watch out for the scene size, it seems like your camera is not focusing very well. Besides that, I can't tell you that much, since I use Cinema 4D for the main platform. If it's plugin related, maybe you could mess around with your scene file, and edit it in notepad, to check if there's is a boolean somewhere, that states Motion blur=true, just to be sure.
Hello thesquirell!
Thanks.
But Cannot find "Motion Blur" ...
Thanks.
- thesquirell
Forget the scene file, lets try by putting your camera exposure time to 1s. Try that out.
It does not work.
- thesquirell
Send me your scene file, and write the version of exporter you are using, I'll try to go in.
Indigo For 3dMax : 0.7.4
- thesquirell
I meant the .3ds file, from your 3ds Max. Opening your Indigo scene file, I can see that you only exported one frame of your animation, which is fine, bit it kinda gives this feeling that you forgot to animate your camera/object, perhaps? Since I can see only two keyframes for camera, which are default ones, and none for the object...better just send me the scene file for 3ds.
Add: Upon closer inspection of the Indigo scene files that were exported with my own scene, the object that was animated was exported in as many new copies as there are frames, creating in the scene files only the keyframe for the camera, not connecting that animated object across different frames. That means that Indigo sees this object as stationary, but on different coordinates on different frames.
I guess it's also possible that IndigoMax doesn't support motion blur? Does anyone actually know?
- thesquirell
Well, it does have a motion blur tick box...would be kinda cruel of having that in, and not supporting it, right?
Come to think of it, the latest 3ds Max plugin is 0.7.4.1, right? That was published on Nov 30, 2019. Fused wrote in another thread about the same issue how he is going to "have a look at what it would take to get motion blur support into 3ds max", which was on Dec 07, 2019. If 0.7.4.1 is the latest plugin, I guess it doesn't work in 3ds Max?
Users browsing this forum: Majestic-12 [Bot] and 11 guests
