Page 1 of 1
big problem with exporting......
Posted: Thu Mar 22, 2007 7:05 am
by Kosmokrator
hi suvakas i attach one of my objects in my new scene in max file format to make and u some tests...also i give an picture of wath i get...i dont understand...what happents?
i also tryed to export in xml and 3ds format....the same thing happends... :roll:
Posted: Thu Mar 22, 2007 7:29 am
by Kram1032
wtf = good name for this :P
Posted: Thu Mar 22, 2007 7:55 am
by filippo
as you have realized the geometries?to importing...ecc
filippo
come hai realizzato le geometrie?importate?
filippo
Posted: Thu Mar 22, 2007 8:02 am
by Kosmokrator
filipo i dont understand what u mean.....the geometrie is editable mesh....i export them in 3ds and xml but give the same result....i think is deeper problem...suv please chek the scene and give me one solution....im about to crazy! :) thnx
Posted: Thu Mar 22, 2007 8:03 am
by Kram1032
realized? Do you mean "applied"?
Î don't know, how the 3DsMAX exporter works, but... import? shouldn't the exporter automatically get the geometry?
Posted: Thu Mar 22, 2007 8:04 am
by suvakas
Scenes like this always come handy for finding bugs (yeah..like there is not enough bugs already :) ).
I'll check it out.
Suvakas
[edit] ups... I have only Max 7 at home. Will check the scene tomorrow at work.
Posted: Thu Mar 22, 2007 9:57 pm
by suvakas
The scene will render fine with next Maxigo version when using a new feature called "Fix Mesh Errors" :wink: (i'm not sure if i should turn that feature ON by default or implement it as a selection box (it is a selection at the moment)).
It isn't 100% fool-proof , but I've been able to render scenes, that were soo messy and didn't work even with M2I exporter, by using that new feature i "invented". It even exports actively linked Autocad models (no X-refed models though..those have to be merged to scene).
So hold on. I will release it as soon as possible (maybe on this week :) Depends on my workload in other areas).
Suvakas
Posted: Fri Mar 23, 2007 4:25 am
by Kosmokrator
ohhh my god......thnx suvakas i have a full modeled scene and i get 80% of my objects with this "boxed" error!
thnx again for your effort to this exporter!
Posted: Fri Mar 23, 2007 5:35 am
by filippo
suvakas wrote:The scene will render fine with next Maxigo version when using a new feature called "Fix Mesh Errors" :wink: (i'm not sure if i should turn that feature ON by default or implement it as a selection box (it is a selection at the moment)).
Suvakas
the"fix mesch errors" there is in this exporter or in the a future exporter?
filippo
Posted: Fri Mar 23, 2007 5:43 am
by Kosmokrator
in the future exporter filippo...... :wink:
