Page 1 of 1
IndigoMax - Error
Posted: Wed Nov 20, 2013 10:31 pm
by Sroka8888
I have a problem....
I can't install IndigoMax higher than 0.3.6 because is a error:
Error opening file for writing:
\plugins\IndigoMax.dlr
My max version:
3ds Max Design 2014
Any ideas how to fix this ?
I test old IndigoMax version, and i want test new Changes
Re: IndigoMax - Error
Posted: Thu Nov 21, 2013 12:13 am
by subpixel
Was max root path specified correctly?
Seems like it was left blank. If that's the case please try to set it manually. Will check if auto-detection works for Design.
Hope it helps,
Posted: Thu Nov 21, 2013 8:24 am
by subpixel
Indeed, there was a problem with path auto-detection for Design versions. It was fixed already, so please re-download installer for testing.
Thanks for info.
Posted: Fri Nov 22, 2013 2:48 am
by Sroka8888
Auto-detection for Design versions Works
But Error is still
When i click ignore, next file have Error and next, next ...
It looks like the files are protected
I check file ,and are not set only to read hmm...
Its strange the version 0.3.6 works, but higher don't...
hmm version 0.3.6 have different installer than 0.3.9 ?
Posted: Fri Nov 22, 2013 3:00 am
by subpixel
Sroka8888 wrote:It looks like the files are protected
Not really, you might see on your screenshots it's copying files to empty path. Which is a bug. Will look into it.
Sroka8888 wrote:hmm version 0.3.6 have different installer than 0.3.9 ?
Yes, it was changed in 0.3.7
Thanks for info.
Posted: Tue Nov 26, 2013 1:01 pm
by subpixel
I have fixed some issues with installer script in new release. Hopefully they should solve your installation problems.
Please let me know if it's working for you.
Posted: Tue Nov 26, 2013 9:41 pm
by Sroka8888
Works
Thank you very much
Posted: Tue Nov 26, 2013 9:42 pm
by subpixel
I'm glad it's working for you
Posted: Sat Dec 07, 2013 6:35 am
by Sroka8888
I need your help.
- How in 3ds Max (IndigoMax) create proxy, something like VrayProxy?
(I want have one "base" Model and others instance - box)
- Where is Mesh Subdivision?
- Where i can find Maxigo Scatter?
- Why when i set Interactive mode render works ,but i have a lot of message --Unknow property: "value" in dotNetControl:render_progress:(null) ?
- I want start render but i have message Error Creating File Output
Posted: Sat Dec 07, 2013 7:52 am
by subpixel
Sroka8888 wrote:How in 3ds Max (IndigoMax) create proxy, something like VrayProxy?
That's something I'm currently working on, should be in next release.
Sroka8888 wrote:Where i can find Maxigo Scatter?
I don't know, possibly in Maxigo.
Sroka8888 wrote:Why when i set Interactive mode render works ,but i have a lot of message --Unknow property: "value" in dotNetControl:render_progress:(null) ?
This is addressed in next 0.4 series
Sroka8888 wrote:I want start render but i have message Error Creating File Output
Could you elaborate a bit? Screenshot, replication steps?
Thanks,
