Page 1 of 1
Max 2012 Support
Posted: Sun Jul 03, 2011 9:20 am
by rawalanche
i am interesting in trying out Indigo renderer since i heard its probably the fastest unbiased renderer currently available. I am a 3ds Max 2012 user. I have read previous threads in this section, and i figured that exporters for version 2.6 and 3.0 are not working (crashing on scene load). So i am curious what is current workflow for customers that bought Indigo and use Max 2012? Or are they still using 2011 and waiting for the issue to be fixed? It is quite a while since 2012 was released. :|
Re: Max 2012 Support
Posted: Mon Jul 04, 2011 9:17 am
by suvakas
Hey,
This crashing on load is not an ultimate show stopper.
Basically it crashes when the Maxigo panel is open at the moment you press Load..
Scene file itself is fine and you can load it back in when you restart Max after it crashes. I'm not at my work Pc atm so I can't verify it, but it may not even crash when you close Maxigo UI manually before loading.
It will be fixed in next Maxigo version.
Posted: Tue Jul 05, 2011 8:18 am
by rawalanche
I see. Thanks for your response. Anyway, even when this issue can be avoided, it still seems like very critical issue, and i wonder what takes so long to fix the issue. I mean, it would be acceptable for free/open source renderer, but since indigo is commercial, this kind of thing should not happen, and there should be stable exporter for current version of indigo.
I have tested it on few of my scenes, and i was really impressed by speed and simple workflow. I would like to present it to my company as an alternative to Mental Ray which causes us a lot of difficulties lately. But as long as the situation stays the same, i cannot do so. I doubt my boss would agree on paying for a solution that is not stable.
I wonder how long will it take until next version of exporter is released... ?
Thanks in advance.
EDIT:
Just tried Maxigo 3.0.7 with Indigo 3.0.12 (Free mode). Scene crashes on every open, no matter if Maxigo panel is opened or not. There is no way to open the scene except merging scene content into a new file. :(
Posted: Tue Jul 05, 2011 11:40 pm
by suvakas
rawalanche wrote: EDIT:
Hmm. Even when you restart Max?
The thing with current Maxigo is, that it is a legacy from times when Indigo was freeware. There's a lot of ugly code inside. At the moment it is more rational to move on to the next level and rewrite the entire thing. I'm almost done with it and if I manage to fix a few remaining issues I can start giving out copies for closed beta testing this week. If all goes well I can upload a public beta in this month. So it's almost there.
Posted: Wed Jul 06, 2011 12:03 am
by rawalanche
Thanks for info. Yes, it crashes even when i restart Max. I am running Max 2012 x64 with SP1. I am looking forward to new version of maxigo.
Posted: Fri Jul 22, 2011 9:11 am
by rawalanche
any progress on new functioning maxigo?
Posted: Tue Aug 09, 2011 8:14 pm
by zed_pmd
When will new version maxigo? I can not open many of the older scenes ...
Indigo is a commercial program already. This problem should be solved long ago ...
best regards,
Zed
Posted: Fri Aug 12, 2011 2:46 am
by lycium
Hi guys, sorry for the lack of response here; this should indeed work, and we're looking into the issues now.
We appreciate your support and patience in the meantime, and will endeavour to get the fix out ASAP.
Posted: Fri Aug 12, 2011 4:38 am
by zed_pmd
Thanks for your reply Lycium. So we wait to solve the problem ;)
Best regards,
Zed
