Maxigo 3.0.7
Posted: Thu Jun 16, 2011 11:29 pm
Hey all,
This is the last Maxigo version that uses maxscript. Next Maxigo will be a proper plugin.
It still has this nasty "crash on load" bug which I wasn't able to track down. I wasn't sure if I should upload this version or not. But I'm still uploading it so you can have something to play with that is more compatible with Indigo 3.x
Suv
Changes in v.3.0.7:
* changed - Aperture shape default values under Camera parameters
* changed - UV sets now use index instead of name
* added - Smoothing option for bump, displacement, opacity and glossiness maps
* added - A, B, C and Gamma parameters for all texture maps of IndigoMain material
* added - Medium to FastSSS material (better SSS effect)
* added - Vignetting option to Camera parameters
* added - Material ID tracer mode to Export scene rollup (renders every material with a different solid colour)
* removed - Frame upload period from Network rendering rollup
