Page 1 of 1
Modeling a crystal glass
Posted: Sat Jul 12, 2008 5:20 am
by tony
Hello everyone.
I modeled a glass crystal and I met with different surprises:
1. Without smoothing, showed their faces.
2. Smoothing, are strangers.
3. EdgeSplit. Continue strangers.
4. Mark Shap (above). Strangers disappear from the top.
5. Mark Shap (below). No improvement.
6. Off "From Edge Angle." It looks good.
I do not know if there is a systematic (in addition to the manual).
Any contribution will be grateful.
Now try with fluid and uploaded the results.
Posted: Sat Jul 12, 2008 5:36 am
by 5OnIt
It seems to me that you are running into the same problem I was. No one really had much of an answer and I never did solve the problem.
Look here...
http://www.indigorenderer.com/joomla/fo ... highlight=
Posted: Sat Jul 12, 2008 6:15 am
by tony
5OnIt:
I think that is not the same problem because I have not applied subsuf only Set smooth + Edge Split.
Anyway I think there will be a systematic for glass objects.
Posted: Sat Jul 12, 2008 6:18 am
by doublez
Can you post the .blend?
Posted: Sat Jul 12, 2008 6:21 am
by fused
OnoSendai wrote:Repeating patterns down the side of a glass happen in real life.
i think thats a feature
Posted: Sat Jul 12, 2008 6:39 am
by tony
doublez:
Here is my blend file.
Posted: Sat Jul 12, 2008 7:02 am
by tony
Now with water.
Render time 1 h 27 m.
Posted: Sat Jul 12, 2008 8:25 am
by 5OnIt
tony wrote:5OnIt:
Some of the renders I did were not subsurfed. I tried every combination of subsurfing, smoothing and edgesplit I could think of. It could never get it to go completely away.
Posted: Sun Jul 13, 2008 8:01 am
by 5OnIt
OK... Tried your "From Edge Angle" suggestion. There is still some strangeness going on with the reflections, but it does seem to be much better. Unsure as to what the small pieces of "dirt" are located on the bottom surface of the glasses.
Posted: Sun Jul 13, 2008 8:14 am
by Borgleader
Wow that looks a LOT better
and I have no idea what those are either.
