Page 1 of 2
colors in blender vs indigo
Posted: Thu Dec 13, 2018 1:17 am
by Nikolaj Knudsen
Hi all
What are the "conversion rule"on colors from blender to indigo? Indigo sets the color darker than piked color in blender. Example hex #c0743e turns into #862c0c.
I get that it has to do with compensating for to bright colors/energy in scenes, but difficult when you're trying to color match ncs or ral color palettes for design.
Nik
Re: colors in blender vs indigo
Posted: Thu Dec 13, 2018 3:09 am
by Oscar J
Would also like to know.
Posted: Thu Dec 13, 2018 3:45 am
by Nikolaj Knudsen
OK- If anyone else can use this.
I made a scene and noted the V value (HSV) from 0-1. This is what I get:
(greyscale)
Posted: Thu Dec 13, 2018 7:24 am
by FakeShamus
doesn't this have to do with Blender's color settings vs the Blendigo export gamma? the color viewing space is editable in Blender's scene tab under color management. But I have also previously edited the Blendigo file to change the the gamma of exported colors (gamma.py, I think...)
Posted: Thu Dec 13, 2018 8:59 am
by Nikolaj Knudsen
maybe, I will try to look into that :)
Posted: Fri Dec 14, 2018 1:41 am
by aleksandera
What are we talking about here? Maybe about this?
The top one is 4.2.21 and the bottom one 4.2.23
The same amount of samples :shock:
https://ibb.co/ZVDf7X2
Posted: Sat Dec 15, 2018 12:02 am
by Nikolaj Knudsen
I think FakeShamus is right. Blender auto correct hex or hsv colors to sRGB colorspace - I think :) . Anyway, the render result with the darker/altered color from blender is closer to the physical ncs color sample in the final output.
Posted: Fri Jan 13, 2023 7:56 pm
by Zalevskiy
2023 still not fixed, tested in Blendigo 4.4.1 and Indigo 4.6.0
Blender > Indigo gamma 1.0
Indigo default material scene gamma 2.2
ps this applies only to a simple Diffuse color, when exporting textures, there are gamma settings :!:
Posted: Fri Jan 13, 2023 10:40 pm
by Zalevskiy
figured out how to get around it
you need to export a material with a texture and gamma 2.2, after 'manually' uncheck ckeckbox a "texture" in the indigo engine environment and then it will be RGB gamma 2.2 ... and if animation is exported, you will have to replace all .igs files through notepad
Posted: Tue Jan 17, 2023 4:44 am
by Headroom
I am looking through the exporter code to see if this behavior can be changed. In the meantime, would an external material work ?
Posted: Wed Jan 18, 2023 6:51 am
by Headroom
As an external material the .igm file would look like this:
<scenedata>
	<material>
		<name>diffuse_white</name>
		<diffuse>
			<albedo>
				<constant>
					<rgb>
						<rgb>0.8 0.8 0.8</rgb>
						<gamma>2.2</gamma>
					</rgb>
				</constant>
			</albedo>
		</diffuse>
	</material>
</scenedata>
Posted: Tue Feb 07, 2023 1:35 am
by MZ
Is this a task specific problem or should colors generally be exported with gamma 2.2?
Doesn't Blender use linear space in colorpickers (except for # codes)?
Edit.
1. Created a sRGB PNG texture texture filled with #AAAAAA color. Blender translated it to 0.66667 value in gamma 2.2.
2. Color picked this texture. Colors look the same, Blender's color picker shows 0.401978
Created two materials (texture and rgb color) and render them next to each other. Seems kinda OK. I'm not sure I understand your problem.
Posted: Tue Feb 07, 2023 2:40 am
by Zalevskiy
MZ wrote: ↑
I don't have a problem anymore, of course, I can manually replace everything in notepad, I'm trying to convey how inexperienced users can see the indigo product from the outside.
Probably, many people who fall into such "traps" cannot find the problem of incorrect data display and are disappointed in indigo, thinking that this is an engine problem. I am sure that indigo is very underestimated, it is difficult to understand it without abstract thinking.
Posted: Tue Feb 07, 2023 2:59 am
by Zalevskiy
#73CF51 color after export #2B9F14
"Blender use linear space" apparently this is the reason for the color distortion.
Posted: Tue Feb 07, 2023 5:42 am
by MZ
One more thing to look out for. Blender treats hex code as a sort of sRGB standard, while in Indigo it is just a 0-255 value representation. So hex in Blender always represents gamma 2.2 corrected color, while in Indigo it is not correlated with gamma.
I see where this is going. Considering future material nodes, I think that standard color sockets should remain in linear space as is color picker and the rest of Blender. However, gamma node can be added, or something like 'color as sRGB' node for less savy users. What do you think?
