how can I start indigo_console.exe instaed of indigo.exe with blendigo.
I need to realize this with a python script not necessery from the Blender GUI.
Best regards,
Phil
Starting indigo_console.exe from Blendigo
Re: Starting indigo_console.exe from Blendigo
You can change it in util.py:
return os.path.join(getInstallPath(scene), "indigo.exe")
But there is also link to console below, so there maybe some kind of switch somewhere, not sure though...
Hi Eneen,
thanks for the quick answer, that is a good start to search investigating.
Yes I see this:
return os.path.join(getInstallPath(scene), "indigo_console.exe")
But I did not find a switch (in the GUI), maybe this is only possible with python, this would be eniough for my need.
I will investigate all the python files...
Yes I see this:
This seems to work as a switch
bpy.data.scenes['Scene'].indigo_engine.use_console = True
I typed this directly in the blender console, and then click on Render.
The process is running but I do not see any dos console...
