How to render animation?
- afecelis
Hi guys,
I've set everything as usual in Blendigo's options to render and animation, however, when I click on the "animation" button only the first frame gets sent to Indigo and rendered, once it finishes the samples I set for it it doesn't pickup the next image
I looked in the forums but there's not much info on animation for Blender, can anyone give me a hand here?
regards,
Alvaro
regards,
Alvaro
Re: How to render animation?
2015!.....
Does Blendigo do any animations? I'm having the same issue. Looked at the manual and at this forum and experimented but it just renders one image over and over.
Is there a work around?
I've rendered plenty of animations using Blendigo. It's far from great but it can do the basic stuff. Can you describe your workflow more in detail?indigoagogo wrote: ↑Tue May 25, 2021 4:46 am2015!.....
Well I set up the scene and press render animation. Doesn't work.
Can I do a series of images and collate later?
It doesn't render it out as a movie, if that's what you mean. It saves images that you then have to put into a video software (or blender) to playback and edit.
It only renders one image. It then constantly writes to that one image name till all frames are done... So in the end you only have one image.
Simple test animation shows fine here. Frame names saved by frame numbers located in "C:/tmp/[Scene-Name]"
Tested using: Blender 2.83.16 LTS w/ blendigo-4.3.0-3adc22b-master (exporter) & Indigo Renderer 4.4.16.
Edit:
Same test also working with Blender 2.92, Indigo Renderer 4.6.0 & integrated Blendigo exporter.
Edit:
del
Thanks for the replies. I had to use Cycles to bridge a gap but I will look at this again on my next work.
Users browsing this forum: Ahrefs [Bot] and 57 guests
