Hello guys,
first of all let me say Indigo is better integrated in Blender than ever - the exporter
works 120% of the time, mostly on the first time!
There's one issue I can't solve since the good old 2.49 exporter and this is
to define an exr/hdr environment texture in blender to be picked up by the indigo
exporter.
Usually a background texture is defined in the 'world/texture tab',
but it doesn't get exported at the moment.
A nice quick workaround would be to add a custom property in the 'scene tab',
whick adds the entry in the .igs-xml,
but I don't know how to format the code, so blender
would write the entry...
Does anyone know, how to format that?
Cheers!
Exporting Environment Textures in Blender 2.5 +
Re: Exporting Environment Textures in Blender 2.5 +
it would make sense to find that option there, but the way you do it is by adding a hemi light, which you can then choose to be a flat BG color or you can add the environment image to.
Thank you, it works really well. It's just not obvious!
It's not obvious but has a distinct advantage. If you'd add it as a world texture you cannot rotate it to fit your scene. With a hemi light you can rotate it.
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Users browsing this forum: Ahrefs [Bot] and 38 guests
