Page 1 of 5
Blendigo 3.8.25.0
Posted: Wed Jan 21, 2015 2:09 am
by fused
Archive: http://downloads.indigorenderer.com/dis ... 8.25.0.zip
Windows Installer: http://downloads.indigorenderer.com/dis ... taller.exe
Should be compatible with Blender 2.69-72
Changelog:
3.8.25.0
* changed blendigo installer to install to appdata directory.
* installer detects blender 2.69-72.
* exact install path can be selected now (for newer, not auto detected version).
* added fresnel scale and fresnel scale channel to phong material.
* added backface emission.
Bug reports and comments welcome!
Note: Since the installer installs to a different location now, make sure you uninstall previously installed versions of blendigo.
Re: Blendigo 3.8.25.0
Posted: Wed Jan 21, 2015 2:15 am
by Oscar J
Sweet, thanks. :)
Posted: Wed Jan 21, 2015 2:40 am
by fused
Updated with a small bug fix to do with the fresnel scale channel.
Posted: Wed Jan 21, 2015 10:21 am
by StompinTom
Will give it a spin! Much much thanks :D
Posted: Wed Jan 21, 2015 10:48 am
by dakiru
StompinTom wrote:Will give it a spin! Much much thanks :D
^ this.
Thank you for your effort :)
Posted: Mon Feb 02, 2015 3:28 am
by Oscar J
Blendigo's light layers doesn't seem to work with suns or ies lights.
Posted: Tue Mar 24, 2015 1:32 am
by SreckoM
I am getting this error when Indigo starts
Error while building scene: ObjectExcep: Frame times must be strictly increasing. (model UID: 10000029)
And there are no particles in scene at all. Any tips on how to debug it, there are a lot of objects in there ...
[EDIT] Figured out, can not use linked libraries.
Posted: Tue Mar 24, 2015 2:37 am
by fused
SreckoM wrote:[EDIT] Figured out, can not use linked libraries.
What do you mean, exactly?
Have a scene to replicate this issue?
Posted: Tue Mar 24, 2015 7:44 am
by SreckoM
Sorry for not being able to respond sooner. In that scene, that I can not share, I had this error until I removed linked libraries(objects) from scene.
Posted: Tue Mar 24, 2015 9:41 am
by fused
SreckoM wrote:Sorry for not being able to respond sooner. In that scene, that I can not share, I had this error until I removed linked libraries(objects) from scene.
What exactly do you mean by linked libraries? I'm not so good with blender lingo :)
Is it a plugin of sorts?
Posted: Tue Mar 24, 2015 9:43 am
by SreckoM
O you mean that. It is like referenced object from another blend file. Basically you have placeholder in your scene that is referencing to object from another blender scene. It can be object, material, image, node etc ...
http://wiki.blender.org/index.php/Doc:2 ... _Libraries
Posted: Sun Mar 29, 2015 11:53 pm
by Oscar J
Would be cool to have access to some more HDRI settings when having selected a Hemi lamp - gamma in particular. :)
Posted: Wed Apr 01, 2015 5:42 am
by SreckoM
Also getting python error on exporting mesh as .igmesh.
Posted: Thu Apr 02, 2015 6:03 am
by Oscar J
The broken light layers panel needs to be fixed, obviously. Changing the values has absolutely no effect at the moment.
Posted: Sun Jun 21, 2015 3:14 am
by Oscar J
Another minor bug: the max SS value in Blendigo is 4. In some cases I find myself having to crank it up to 5, would be nice to be able to do that in Blendigo.
