Page 1 of 1
alpha material
Posted: Sat Jan 20, 2007 3:58 am
by aliensigns
hello,
i need help for creating alpha material.
i've see an example of blend material....but how i do in blender this material?
is this possible an example of a creation of this material with image (like a tut?)
thank you of all and sorry for my bad english (i'm italian)
aliens
Posted: Sun Jan 21, 2007 2:04 pm
by Bandar
It is not possible to use a real alpha material. But there is a workaround now:
1. Make one material, that shoul "show up"
2. Make a second "null" material (<null_material/>)
3. Make a 3rd material, that blends mat1 and mat2 using a map, that tells indigo, where which material should show up. Since mat2 is "null", you get alpha.
Sorry, if my description is not very clear, but its late and my english went to bed already :oops:
thanks
Posted: Tue Jan 23, 2007 9:16 pm
by aliensigns
thank bandar.....but i don't understand if there is not an example with some images.......i don't know how to make a null material and then blend with the 3 material.......
thanks
Posted: Tue Jan 23, 2007 9:27 pm
by Bandar
You have to code it by hand I guess...
like this:
<material>
   <name>a</name>
	<phong>
              <nk_data>nkdata/ag.nk</nk_data>
              <exponent>1000</exponent>
         </phong>
</material>
<material>
   <name>b</name>
         <null_material/>
</material>
<material>
   <name>pseudoplphamat</name>
	<blend>
		<a_name>a</a_name>
		<b_name>b</b_name>
		<blend_factor>0.5</blend_factor>
		<blend_map>
			<uv_set>uv</uv_set>
			<path>pseudoalphamap.jpg</path>
			<exponent>1.0</exponent>
		</blend_map>
	</blend>
</material>
So "pseudoalphamap.jpg" is your alphamap, applied as an uv texture (you can do that in blender and export).
Material "a" is the material, that shows up where no transparency is (could be any material, also a uv mapped one.
Material "b" is your "nullmaterial" - which means, there is no material - which means your object is transparent.
Hope, that helps a bit.
Posted: Tue Jan 23, 2007 9:28 pm
by Bandar
like this:
<material>
   <name>a</name>
	<phong>
         </phong>
</material>
<material>
   <name>b</name>
         <null_material/>
</material>
<material>
	<blend>
		<a_name>a</a_name>
		<b_name>b</b_name>
		<blend_map>
			<uv_set>uv</uv_set>
		</blend_map>
	</blend>
</material>
thanks 2
Posted: Tue Jan 23, 2007 9:36 pm
by aliensigns
ok thank bandar for explanation......but the question is: in blender is possible to create this material?
or i do this make a modification of xml code?
thanks
