Requests: Set Render location and Set Priority
- Doug Armand
#1: I'd like to request the ability to set where the Renders/IGI's are saved to.
I really don't want them always saved to the default location of C:\Users\UserName\AppData\Roaming\Indigo Renderer\Renders\
#2: I would really like to be able to set the Thread Priority to Low in Blendigo so that Indigo loads in that mode.
Doug
Doug Armand
Doug Armand
Re: Requests: Set Render location and Set Priority
+1 for the #1 : I asked myself several times for that feature. At least,saving igi files in the same location as png files.
the first one is already done, in the next release it should be in. for the second you should ask Nik to take the priority option back again.Doug Armand wrote:#1: I'd like to request the ability to set where the Renders/IGI's are saved to.
Check normals, dude!
Den,
just use START /BELOWNORMAL
works perfectly, even with indigos low thread priority switch. even if it is set to normal
- Doug Armand
ExcellentSmartDen wrote:the first one is already done, in the next release it should be in.
Doug
Doug Armand
Doug Armand
ETA on the next blendigo release?
- Borgleader
When its readyGodzilla wrote:ETA on the next blendigo release?
ETA on when it will be ready?
We're working this through with SmartDen at the moment. Should be any day now - there are obviously some bugs with Blendigo we need to sort.
