Page 1 of 1
New igi format and Violet
Posted: Wed Jul 23, 2008 11:00 pm
by rob_botch
Hi
I am in the middle of rendering an image in Indigo 1.1.5, saving as an IGI file. When I try to open this in Violet, I get the error message: "Invalid image ile: invalid version". I assume this is related to the change of IGI format. Is there any way t open this file for tonemapping?
Thanks
Robert
Posted: Wed Jul 23, 2008 11:03 pm
by BbB
Can you render your scene ok in 1.1.6 or 1.1.7? If yes, you can do the tonemapping there...
Would be good if the new Indigo could read igi files...
Posted: Wed Jul 23, 2008 11:05 pm
by rob_botch
Hmmm... not really, as I'm exporting using Blendigo, which only goes up to 1.1.5 I think. I guess I could try resuming with 1.1.7 after this has finished, just as far as saving a file.
Thanks anyway
Posted: Wed Jul 23, 2008 11:46 pm
by BbB
You should be able to read scenes generated by Blendigo in Indigo 1.1.7. But without access to any of the new 1.1.7 features of course.
Posted: Thu Jul 24, 2008 12:02 am
by Borgleader
BbB wrote:Can you render your scene ok in 1.1.6 or 1.1.7? If yes, you can do the tonemapping there...
If I remember correctly. To read igis in the new indigo just resume your scene. pause it and then play with the tonemapping settings. Or at least I think thats what ono told me.
Posted: Thu Jul 24, 2008 12:22 am
by BbB
That's a very good thing this.
Posted: Thu Jul 24, 2008 12:40 am
by OnoSendai
Yup, it's a rather roundabout way, but it's the only way currently.
Posted: Sat Jul 26, 2008 2:59 am
by rob_botch
Hmmm... it sounds alright, but whenever I try to run 1.1.7 with or without an igi resume I simply get a C++ exception.
Posted: Sat Jul 26, 2008 5:20 am
by CTZn
Inversely you may be able to resume your scene with a backwards version of Indigo wich provides a supportable igi.
Posted: Sat Jul 26, 2008 5:38 am
by rob_botch
I'll give that a go later, but won't that cause the same problems as with Violet, namely that the newer version of the IGI spec is incompatible. If this incompatibility is due to additional ignorable information, is this easy or even possible to remove by hand in notepad or similar?
Thanks
