Page 1 of 1
caustics behind dielectric??
Posted: Sat Dec 01, 2007 11:49 am
by Slobodan
I'm reading that MLT based renderers have issue with caustics behind dielectrics. What's the deal with that?? Can Indigo do those??
Thanks,
Slobodan
Posted: Sat Dec 01, 2007 11:54 am
by Kram1032
yes it can, since some time, now.
There already was a HUGE test-thread, which showed the problem and went on, when the problem was solved and much more recently, there was a test, again :)
You just need to make sure, that your Max_num_consec_rejections (a render-setting, found in the inifile and in theory also in your exporter's gui) is at at least 1000 - then, you should see caustics through transparent stuff :)
Posted: Sat Dec 01, 2007 5:48 pm
by CTZn
Or you don't use bidir and wait some more...
Posted: Sun Dec 02, 2007 4:55 pm
by Slobodan
Thanks for reply guys..
I was at NextLimit forum and some people bitched about not being able to see caustics behind transperent stuff. Someone said that is common for MLT renderers. I was sure though that indigo can do that.. :)
Posted: Mon Dec 03, 2007 3:54 am
by Kram1032
as I said, it can, but not since too long :)
Posted: Wed Dec 05, 2007 12:18 pm
by CoolColJ
as long as you have bidrectional on and MLT with MNCR at least 1000 then you will see them given enough rendering time
Maxwell is just Path tracing, no MLT there, so you will never see caustics behind glass ever :)
need MLT for that
Posted: Wed Dec 05, 2007 12:28 pm
by psor
" ... need MLT for that"
That's the point! :D :D ;)
take care
psor
