Reintegración.
Reintegración.
Hello, here goes the link to share my bests investigations on Earth and Moon simulations with Indigo.
https://www.dropbox.com/scl/fo/qdv3whk7 ... 3jr3nrde4t
I´m not sure what it contains, is from two years ago...
Not sure if the link works. If not I will need help to make it work.
You are able or allowed to do commercial projects with it, almost from my side. All the maps are of free use and are acquire from internet. Actually the maps are inside the pigs on the material folder. You need C4D to start to work! Don´t forget to relink the materials and maps of control inside cinema.
Enjoy it! Please, post here the results and share further developments...
Re: Reintegración.
Re he valuación de RëHHëN más coloro métrica.
Re: Reintegración.
Last day to pick up the files: 21 May 2023... Dropbox will be out of free use in this day.
Re: Reintegración.
I think that in some days I will try to upload the files again corrected, maybe in drive...
No one picture at the moment .
Here goes one, 4K, look the detail of the moon. Displacement/bump maps of 140K pixels of with if I remember well. 41 minutes.
Re: Reintegración.
50 minutes, 310 samples/pixel.
17º above the horizon. Sun zenith 72º. Reinhard solution, indigo´s output.
Re: Reintegración.
16 minutes, 292 samples/pixel.
19º above the horizon. Sun zenith 72º. Reinhard solution, indigo´s output. Bidirectional path tracing.
Re: Reintegración.
6K.
30 minutes (Himalaya). Path tracing.
3 hours (Moon). Bidirectinal MTL.
In a days I share this two scenes in drive.
As post produccion I introduce a subtle base curve compression.
I prefer this kind of tonemapping/post production for the work. I explore the LUT game for a long time. Is good, but I prefer this. I can believe in the blue of the sky, etc. White balance E preset.
I obtaine a more poligonized mesh when I extract the visible polygons for the view from the Earth and Moon spheres, but has inconvenients. Worked with 64 GB of RAM. The material has been reevaluated with the proper map...
Reinhard tonemapping (5,1,6 2.5,1,6).
Re: Reintegración.
Still fixing some things, clouds map refine with Topaz IA.
20 minutes.
20 minutes.
Re: Reintegración.
13 hours.
D65 white balance re introduced.
Re: Reintegración.
Launched in 12K, SS 1, and downsized to 4K.
5:45 hours, 150 spp.
Some fireflies washed.
Re: Reintegración.
Focal length 50 mm instead 80 mm.
MTL values: large mutation probability 0.05, max change 0.01
30 hours, 6000 spp, 4K.
Still some noise... I have some ideas to test... time... I investigate now with MTL because of this one, very noisy because snow and ice. With path tracing I can wash the fireflies of the ocean in 5 minutes, but...
Users browsing this forum: steklodelsgh and 48 guests
