hex to rgb color
8 posts • Page 1 of 1
byraul
hex to rgb color
Post by byraul » Mon May 28, 2007 12:41 am
how can i convert a color from hex code (#ff00ff) to RGB vector?
dougal2
Post by dougal2 » Mon May 28, 2007 1:30 am
split the hex into three parts, two characters each
ie. #FF00FF is
R - FF
G - 00
B - FF
then convert those parts to decimal
R - 255
G - 0
B - 255
jurasek
Post by jurasek » Mon May 28, 2007 3:57 am
first link from google:
http://bontragerconnection.com/tools/co ... rter.shtml
greetz,
jur
Post by CTZn » Mon May 28, 2007 5:05 am
you can use the calculator under Windows, switch to scientific mode in the menu:
Start > Run > calc
Post by Kram1032 » Mon May 28, 2007 7:32 am
or start -> Programs -> ___ (= Extras? In german, it's Zubehör...)
byraul
Post by byraul » Mon May 28, 2007 9:40 am
hmm.. why blender exporter is creating RGB colours with values <1 ?
colour
Sets the RGB reflectance (albedo). All components should be in the range [0, 1)
Each component will be silently clamped to the range (after reverse gamma correction) [0, 0.9].
As of 0.7 test2, the RGB colour will be 'reverse gamma corrected' – all components will be
converted to display values by raising to the power of 2.2.
type: real 3-vector
restrictions: Each component should be in the range [0, 1)
units: dimensionless
From manual....
Post by CTZn » Mon May 28, 2007 10:30 am
Then divide the result by 256 !
Post by Kram1032 » Mon May 28, 2007 11:37 am
exactly
very simple
If you maximum result is 255, but it SHALL be 1, just divide by 256 (the +1, 'cause of 0 also is a value)
