[BUG] SSS => darker image
Meelis
Re: [BUG] SSS => darker image
Post by Meelis » Sun Mar 21, 2010 8:03 pm
MTL & Bdir off doesnt help, or does indigo use MTL for SSS by default.
No help turning off cauchy b coeff, lowering ior, iso 25, EV 0
Reinhard looks black, camera white.
Maybe it's some unphysical disbalance between absorption and scattering.
galinette
Post by galinette » Mon Mar 22, 2010 12:07 am
About the first image : advanced tonemappers should not be used to compare scene lightness, as they use complex local/global light correction. Sometimes, a small darker or brighter object in the image results in overall change in brightness with camera and reinhardt.
Therefore, linear is the only correct way to be sure that brightness has really changed.
Eclat-Digital Research
http://www.eclat-digital.com
Meelis
Post by Meelis » Mon Sep 12, 2011 5:41 pm
galinette wrote:About the first image : advanced tonemappers should not be used to compare scene lightness, as they use complex local/global light correction. Sometimes, a small darker or brighter object in the image results in overall change in brightness with camera and reinhardt.
I tested again high SSS value in 2.4.13.
It rendered fine some time maybe 30 minits or so, then after 1 hour about there was random color pixels, no shape of geometry. Even linear doesn't help.
BTW insane how fast is rendering speed in simple path mode, no MLT no BiDir.
Perhaps it was fixed in Indigo 3.xxx
I upload the material for testing, if someone is interested
The material doesn't render with BiDir.
Human Blood V2 (11.09.2011).7z
IGM file
(1.91 KiB) Downloaded 176 times
Meelis
Post by Meelis » Mon Sep 12, 2011 8:50 pm
It seems to be fixed in new Indigo. :)
After 1,5 hour the render looks fine.
Meelis
Post by Meelis » Thu Sep 15, 2011 9:21 pm
Indigo 3 ROCKS so hard :D
26 hours and no problem with darkening.
:D
<uniform>
<value>13440</value>
</uniform>
Post by Zom-B » Thu Sep 15, 2011 10:11 pm
I have to test my old scene too, but your rendertime is unacceptable O.o
If you also raise the absorption spectrum you'll notice a nice speed bump!
Meelis
Post by Meelis » Fri Sep 16, 2011 12:16 am
Yeah i better lower the SSS, but still very impressive speed fot single dual core cpu.
