Page 1 of 2
KD tree bug - again
Posted: Sun Mar 29, 2009 9:07 am
by fused
with version 1.1.18 x64.
BVH is ok, kd tree misses lots of intersections
(also, there are quite a few fireflies and the longer i render the more fireflies turn up. weird, because i only used diffuse materials. pathtracing without bidir)
Posted: Sun Mar 29, 2009 10:41 pm
by Kram1032
at least, they don't turn black anymore... xD
Posted: Tue Mar 31, 2009 4:35 am
by PureSpider
They just turned black cause not much light got inside the poly-holes... Same issue as far as I see it
Posted: Tue Mar 31, 2009 8:52 am
by fused
Did some testing on the firefly issue.
All renders are with linear tonemapping.
Blackbody emitters, PT.
Blackbody emitters, bidir PT.
Blackbody emitters, MLT.
Blackbody emitters, bidir MLT. note how different it looks compared to the other blackbody versions.
Sun, MLT.
Sun, PT.
RGB emitters, PT.
RGB emitters, MLT.
Emitters are scalted by the factor 5 this time. Fireflies disappear.
RGB emitters, PT.
Posted: Wed Apr 01, 2009 1:44 am
by Kram1032
very nice test
So, the kd-problem is solved? Or are they all with bvh?
Posted: Wed Apr 01, 2009 3:07 am
by fused
all with bhv, kd is still borked.
but ono said that hell fix the firefly issue.
Posted: Wed Apr 01, 2009 3:14 am
by SATtva_
I hope you meant "he'll". :)
Posted: Wed Apr 01, 2009 3:17 am
by fused
by CTZn
Everyone wants chaos to be under control, that's insane
Damnit, PT is PT... or is it really "broken" ? Though, any fix is a good thing.
Posted: Wed Apr 01, 2009 3:18 am
by fused
CTZn wrote:Damnit, PT is PT... or is it really "broken" ? Though, any fix is a good thing.
well, obviously its not working correctly when using small emitters. "broken" is probably different
Posted: Wed Apr 01, 2009 3:29 am
by CTZn
I don't see this as being incorrect, just unwanted
It would need an expert to confirm or infirm my says, but I believe that simple PT is archaic and that fireflies are the normal result of that stochastic(=random?) process wich uses no guides (optimisations) afaik. So reducing or removing fireflies would change the nature of pt to something different, that's my belief. I'm wondering if the request is sane, really.
When I want to reduce path tracing limitations to a maximum, I use plain MLT
Well bidir does a great job too isn't it ?
Posted: Wed Apr 01, 2009 4:28 am
by Kram1032
tiny light-sources often make problems...
As it's rendering from Camera to Lightsource (to avoid dead rays), Indigo needs to randomly find a lightsource. A big emitting area allows faster convergance, as it's more likely to be found.
That's also, why Indigo with more lightsources rather gets more efficient than less. - the more direct light, the less indirect one
Posted: Wed Apr 01, 2009 4:54 am
by fused
Kram1032 wrote:tiny light-sources often make problems...
yep accepted and confirmed
CTZn wrote:I don't see this as being incorrect, just unwanted
sorry ctz, but this doesnt sound logical for me. also, you know ono and how he is having and eye on staying as physically correct as possible. i guess if this was a usual limitation of PT he wouldn't have said that i can and will be fixed?
regarding plain MLT: take a closer look, it has fireflies, too!
Posted: Wed Apr 01, 2009 9:05 am
by CTZn
Well,
my logic beneath is that having fireflies in a render does not mean it's biased. If you have 3 fireflies on an image that means 3 unwanted samples amongst thousands, as you know. That is acceptable for me, furthermore because supersampling gets rid of ff like a charm.
Again I'm not an expert, I'm exposing own beliefs more than arguing and I would like to know more on that topic (are ff inherent to pt ?)
edit: on the MLT render with ff: is that reproducible ?
Posted: Wed Apr 01, 2009 9:21 am
by fused
download the scene and try it
the longer you render the more fireflies turn up and won't go away. this is definitely an issue
