Page 1 of 4
Alpha render?
Posted: Wed Jan 16, 2008 1:42 am
by Pibuz
..not an essential one, but should be useful for some of us to have an alpha map optional output, showing in black the plane sky areas and in white anything else! :D
Does it sound possible and/or useful to anybody here (excepted me)?
Posted: Wed Jan 16, 2008 2:01 am
by Zom-B
This can be simply done by using your main 3D app,
rendering an Mask or your alpha map should be possible there in seconds
with some few clicks... merging this mask/alpha Map with Indigos rendering output in the gimp or PS should get fast too...
Posted: Wed Jan 16, 2008 5:35 am
by Pibuz
..sorry Zomb..
I didn't get what you mean.. :oops:
Posted: Wed Jan 16, 2008 6:19 am
by alexmeyer
He means, since you model your scene in some 3d app (I'm assuming you don't model in indigo's xml... :lol:) you can render the scene in that program, with alpha output, and just use that. I dunno which program you use to model, but it shouldn't be too hard to figure out.
Posted: Wed Jan 16, 2008 6:47 am
by Zom-B
yes, exactly alex... sorry for the confusion, english isn't my native language :oops:
Posted: Wed Jan 16, 2008 7:00 am
by alexmeyer
Heh, no problem. (actually, you do fine, I can understand your post ok.)
Posted: Wed Jan 16, 2008 10:14 am
by Kram1032
Some minor mistakes (as in everyone's posts), but fully readable ;)
Posted: Wed Jan 16, 2008 11:21 am
by Pibuz
..sorry..
i didn't understand perhaps because i use SketchUp as a modeler, so i can't do any rendering of the scene with alpha map! :cry:
Sorry i didn't get it at first glance..
Posted: Thu Jan 17, 2008 4:56 am
by Whaat
Pibuz wrote:..sorry..
You can do an alpha render with SU (kind of..)
1) Change your background color to 100% white
2) Change your front face and backface color to 100% black
3) Switch to monochrome face style
4) Export the image and edit it (invert) if required
There is a way to render alpha using SkIndigo monochrome mode too:
2) Create a 100% black diffuse material
3) Change your render settings environment to 'SketchUp Background Color'
4) Switch to monochrome face style
5) Render the scene - hint: use camera tonemapping to get a pure-white background
6) When asked what material to use for monochrome render, select the 100% black material
7) You might have to do some post image editing of your render (contrast, invert) to get the final alpha image you want.
Posted: Fri Jan 18, 2008 5:14 am
by v_mulligan
It's an annoying workaround -- especially with scenes with a lot of geometry, that take a while to render. Also, it can be hard to match the depth of field settings in Indigo and in the renderer used to make the alpha channel -- particularly if the other renderer doesn't support non-circular apertures. The transparency of atmospheric effects (smoke, fog, etc.) would also be impossible to reproduce properly with another renderer. I really have to go with Pibuz on this one; any professional renderer should have an alpha output option, and Indigo is no exception.
Posted: Fri Jan 18, 2008 5:09 pm
by OnoSendai
Thinking about this request a little more,
the ultimate goal is to composite Indigo-rendered images over an existing background, correct?
Posted: Fri Jan 18, 2008 5:16 pm
by psor
"Thinking about this request a little more, the ultimate goal is to composite
Indigo-rendered images over an existing background, correct?"
YES! 8) :D ;)
take care
psor
Posted: Fri Jan 18, 2008 5:18 pm
by OnoSendai
Ok, I'm gonna have a think about how to do this best.
Posted: Fri Jan 18, 2008 5:20 pm
by psor
Yeeehaaaa! Finally! :oops: :lol: :wink:
Thanx! ;o))
take care
psor
Posted: Fri Jan 18, 2008 5:29 pm
by OnoSendai
Ok, I've thought of one way.
It would involve two master buffers; I wonder if using 2x the amount of memory for the buffer than usual will be alright for people?
