Page 1 of 1
.:: EXIT-PORTALS and 0.9T2
Posted: Sat Jul 21, 2007 3:56 am
by tizxx
Why when I use dielettric materials I see this circle on exit portal plane ?
Posted: Sat Jul 21, 2007 5:23 am
by jurasek
man..don't answer the phone!
greetz,
jur
Posted: Sat Jul 21, 2007 5:46 am
by BBjam
seven raaaaysss.... err daaaayyssss.....
Posted: Sat Jul 21, 2007 6:09 am
by Kram1032
xD
lol
btw, nice rayshot caustics^^
Posted: Sat Jul 21, 2007 6:34 am
by ortega
jurasek wrote:man..don't answer the phone!
greetz,
jur
:lol: :lol: :lol: :lol:
Posted: Sat Jul 21, 2007 9:50 am
by suvakas
ups..that may actually be a Maxigo bug.
Do you have "Fix Mesh Errors" turned on? If yes, then see if that "ring" goes away when you turn off the error fixing.
If it doesn't, then it's not a Maxigo bug. If it does, then it is 8)
Posted: Sat Jul 21, 2007 10:05 pm
by tizxx
No I not turned on the FIXED.
If I put the teapot more far the circle is not visible.
Posted: Sat Jul 21, 2007 10:09 pm
by suvakas
Then it should not be Maxigo's issue...i think..
Can you share the *.max file?
Posted: Sun Jul 22, 2007 3:23 am
by tizxx
yes this is .max file (3d studio max with SP2)
and again another little issue...
If the plane (exit-portal) is not aligned with the wall inside
the room I see the circle and a black area out-side the exit-portal
probably I'm wrong something... but I not understand what...
:lol:
I USE:
- Intel Core Duo 2 -- 1.8 GHz -- 2GB DRAM
- ATI Mobility Radeon X1400
Windows XP Professional with Service Pack 2
3D Studio MAX 9 with SERVICE PACK 2
Indigo Render 0.9 T2
Max to Indigo - 0.9.3c
Posted: Sun Jul 22, 2007 4:41 am
by tizxx
probably I solved the problem.
The proble is the MAX object Teapot
this standard version of teapot has in some edge the
normal inverted and this is what you see in exit portal
the exit-portal is like a mirror of wrong normals?
so If i put a shell with 1 unit to teapot and I tranform the
entire object to polygons all is ok...
- The problem of black area out-side the exit portal I not solved...
the current image is a shell teapot...
