can you explain me with a simple example? thanks!!!Zom-B wrote:Why not saving each LL to a own file and then do your Animation inside a proper Video Editor??
With such a small team like Glare is I would like rather to see them focus on the core features and enhancements instead of bringing stuff that other Software is capable of way better...
#DontWasteDevTime
Seeing the Chaotica tonmapping features would be sweet, since (afaik) it can be ported quite simple because of the same GUI framework
[REQ] v4 video functionality
Re: [REQ] v4 video functionality
I actually did dude!snorky wrote:can you explain me with a simple example? thanks!!!
http://www.indigorenderer.com/forum/vie ... 84#p134584
Here now step by step, but for best result you should do this in 32bit mode with untonemapped EXR files:
- ani.zip
- (121.31 KiB) Downloaded 135 times
Hi
And 'desirable greater integration between softwares and Indigo for inquiries concerning the animations. Given the high level of the images that produces Indigo is a shame not to exploit them for a movie. The system available today is certainly not encouraging!
I have NO idea what you actually talk about!contegufo wrote:And 'desirable greater integration between softwares and Indigo for inquiries concerning the animations. Given the high level of the images that produces Indigo is a shame not to exploit them for a movie. The system available today is certainly not encouraging!
I do Animations with Indigo on a regular basis, and the missing Renderpasses and automated saving of LightLayers to separate files are the only two things that I can think about that is missing... well... faster rendering actually is always a great feature too
Please explain your missing features!
One of the most gorgeous Indigo animations by kklors: https://www.youtube.com/watch?v=3erlUfylFAE
- pixie
jawdropOscar J wrote:One of the most gorgeous Indigo animations by kklors: https://www.youtube.com/watch?v=3erlUfylFAE
Hi
I have Indigo for Cinema 4D 3.8.26.2 (Mac) but I do not see "export animation".
Where is it?
Where is it?
It should be there, doublecheck that you really have the latest version installed, best reinstall!
Maybe your installation somehow... failed... no idea about mac since I'm on PC.
Hi
I have Cd4 13, Cd4 15, Cd4 17 and the latest version of Cindigo. In none of the three versions is "export animation".
Simply because not implemented? Just as well you can only run one instance at a time!
This is known to developers.
Actually something going on, but I do not understand ......
- 07.jpg (56.11 KiB) Viewed 3225 times
- zeitmeister
I think it is exporting the Animation automatically, when more frames but the active arme being defined in the c4d Export Settings.
Cheers, zeiti
Cheers, zeiti
You have to set a halt time or halt spp if you want to render an animation obviously.
Hi
Halt time or halt spp; what the criteria should be set?
These parameters are found in C4D?
You can find those in one of your screenshots. Whether to use halt time or halt spp depends on whether you want a certain amount for time/frame or a certain spp/frame.
how does it determine in advance when a frame is ready?
Users browsing this forum: Majestic-12 [Bot] and 54 guests
