Page 1 of 1
Indigo freezes while rendering
Posted: Tue Jan 26, 2016 6:54 am
by vasco
I am currently working on scene and Indigo freezes while rendering. Never had that before in Indigo. Here is the scene.
https://onedrive.live.com/redir?resid=D ... ile%2cpigs
Re: Indigo freezes while rendering
Posted: Tue Jan 26, 2016 7:43 am
by OnoSendai
Indigo version?
Posted: Tue Jan 26, 2016 7:58 am
by Zom-B
Tested here and had no real problems.
Only your 766MB big IGS file with all that grass instances is hard to scroll through in the Indigo GUI.
DO you maybe have OpenGL preview enabled? If yes, then try to render with that window closed.
Posted: Tue Jan 26, 2016 8:05 am
by Oscar J
Works perfectly fine for me too. 16 GB of RAM here.
Posted: Tue Jan 26, 2016 8:31 pm
by vasco
Okay closed OpenGL Preview window and now it works. Tkank you Zom-B. btw I am using v3.8.29 and got 16GB of Ram.
Posted: Tue Jan 26, 2016 8:54 pm
by Zom-B
vasco wrote:Okay closed OpenGL Preview window and now it works. Tkank you Zom-B. btw I am using v3.8.29 and got 16GB of Ram.
Glad I could help
BTW: the Normal Maps on the Grass have gamma set to 2.2. To work as intended gamma for normal Maps need to be @ 1.0.
Also is blending 50/50 of Phong with diffuse transmitter quite much of the last one. Usually 20 to 30% of DT should be enough for a nice result...
Posted: Tue Jan 26, 2016 11:37 pm
by vasco
Hello Zom-B, I found the option to set the normal gamma in Indigo GUI but unfortunately there is no option for this the blender exporter
, but thanks for the tips anyway.
Posted: Wed Jan 27, 2016 1:09 am
by Oscar J
vasco wrote:Hello Zom-B, I found the option to set the normal gamma in Indigo GUI but unfortunately there is no option for this the blender exporter
Actually there is. Go to the texture for your normal map, there will be a gamma slider there.
Posted: Wed Jan 27, 2016 2:41 am
by vasco
okay, found it. My fault.
