Page 1 of 1
DoF and Instancing
Posted: Tue Jan 23, 2007 12:45 am
by Bandar
It seems, that when using multiple instances there is no DoF. First I thought it is due to the <autofocus/> but when i removed it and tried even an aperture_radius of 0.5 nothing happened.
Posted: Tue Jan 23, 2007 1:55 am
by domparis
No prob with instancing and dof here, perhaps a scale problem, be sure to work with real value as possible, it help of anticipation of what dof will look, remember that indigo working unit is meter.
Dom
P.S.: Be sure to correct the focus distance correctly, don't know what exporter u used
P.S.2: Sorry for my english :oops:
Posted: Tue Jan 23, 2007 6:38 am
by zsouthboy
DoF isn't something that can "break" in Indigo, just because of the way it works :)
More than likely your scale is too small.
Posted: Tue Jan 23, 2007 9:23 am
by manitwo
zsouthboy wrote:More than likely your scale is too small.
i think you meant too big 8)
Posted: Tue Jan 23, 2007 10:12 am
by zsouthboy
No, smaller.
If his scale was for example 1 cm per unit, DoF (technically, less depth of field) would appear to be very wide, even at large apertures.
Increasing his scene by 100x would make the DoF appear correctly, in relation to "sensor", lens length, and aperture (as circle of confusion is dependent on these factors).
Posted: Tue Jan 23, 2007 10:28 am
by Bandar
how can i scale a whole scene?
