Page 1 of 1
Indigo closes while rendering
Posted: Fri Jan 12, 2007 3:59 pm
by thuleke
I have a problem. Indigo closes everytime I am trying to make a render. Sometimes one hour after initiation and sometimes more (four, five hours).
It does not show any messagge, just closes down and does it. I thought that was related to an error of the file but after some modifications that I have made, it has the same behavior. I tried to do it in other computer and did not work either. Help!
With other file is the same....Indigo Closes !!!
My computer is:
AMD ATHLON XP 2200+
1.34 GHZ Y 1GB DE RAM.
Thank you,
Daniel
Posted: Fri Jan 12, 2007 7:47 pm
by CTZn
Look here, if that was the file Indigo would not start render.
http://www.indigorenderer.com/joomla/fo ... php?t=1035
Posted: Sat Jan 13, 2007 1:03 am
by thuleke
No, my PC don´t restart..my PC is ok.
Posted: Sat Jan 13, 2007 2:00 am
by Zom-B
sounds like a typical RAM issue for me...
Try to memtest your system, or simply just try to reduce Clock Speed of your memory, and check if Indigo keeps killing it self...
raising the voltage of your RAM (a little) is also common to stabilize the Memory...
Posted: Sat Jan 13, 2007 2:52 am
by arneoog
sure that you don't mess with the Halt time option?
it should be set to -1 ...
Posted: Sat Jan 13, 2007 3:18 am
by CTZn
Oh yes I misread you sorry
Ever get the task manager opened while you are rendering, thought once the preprocess is done memory consumption is very stable AFAIK, should be something else, again... what arneoog said ? there is a log.txt in Indigo's folder, what says ?
Posted: Sat Jan 13, 2007 3:35 am
by thuleke
Indigo closes after 10 minutes of rendering, 1 hour, 3 hours or 5 hours of rendering.
Halt time is ok, is -1
It´s a misterious !!
Posted: Sat Jan 13, 2007 3:54 am
by CTZn
Posted: Sat Jan 13, 2007 4:29 am
by thuleke
Ok, the log.txt file says:
scene file path: 'C:\indigo\testscenes\imagine2.xml'
Using working directory path 'C:\indigo\testscenes'.
created world.
Loading Scene 'C:\indigo\testscenes\imagine2.xml'...
Posted: Sat Jan 13, 2007 5:09 am
by CTZn
Is that all ?
Weird, if that's not a memory issue I have no clue of what is happening... Please answer these questions:
1° What are the size of the file (optionally, how many triangles are there ?)
2° can you check in the Task Manager if ram hits a peak ?
3° t'es french Daniel ? (1GB
DE RAM)
4° version of Indigo used ?
Posted: Sun Jan 14, 2007 1:13 pm
by thuleke
Hi , the problem has been solved !!!!
I had to unable the "bidirectional" function.
Will the render quality be affected ?
Thank you!!
My answers:
1- 6 mb
2- 4900 kb
3- I m from Uruguay, South America
4-Indigo 0.6 and Blender exporter 0.5 y 0.6
Posted: Sun Jan 14, 2007 5:55 pm
by qinjuehang
Bidirectional is buggy in v5. In v6, I don't have any issues...is that why?
