Page 1 of 2
Vases
Posted: Wed Jul 02, 2008 1:05 am
by Pibuz
..though (as you ALL know) i'm not satisfied at all with the floor mat..
Thank Kwisten for the postprocessing technique, and Whaat for the polyreducer Sketch plugin and the UVmap tools: as you can see, half of the problems have been solved :D THANKS!
PS. for BbB: it's all your fault, if i've posted this!
Posted: Wed Jul 02, 2008 1:08 am
by SimonLarsen
Nice render.
Why aren't you satisfied with the floor? I think it looks great! :D
Posted: Wed Jul 02, 2008 1:11 am
by Pibuz
Thank you Simon! I'm not happy for the joints.. I cannot achieve a bumped surface using a blending of two materials.....URGH! :x
Posted: Wed Jul 02, 2008 1:18 am
by kwistenbiebel
Very nice Pibuz :)
I love the vases.
Maybe alligning the verticals in the perspective would be even nicer.
I haven't used the' shift lens' feature in skindigo yet, but I think it could be useful for this.
And oh yeah..cough..cough....displacement... cough..
Posted: Wed Jul 02, 2008 1:30 am
by Pibuz
Hi Kwisten! Thanks!
I'll try re-rendering with vertical lines, you're right about that..
Concerning displacement... I don't think i'd be so necessary, here: if you're referring to the tiles, actually..
I think i'd encounter the same problem. I think the problem is that a material (white one) starts just where the other one (black one) ends, so this is the cause of all of my problems. I could simply make a bump map blending in Photoshop the tile textures and the black/white bump map, and then make an exponent map in the same way: i think i'd be sufficient to get the result i'm aiming to..
Know what? I'm gonna do that!
..i just wanted to figure THIS out, cos this time there is a simple workaround, but in other cases it could be much more difficult...
Sorry, one question: which version of Indigo/skindigo do you use? Cos i'm very very very interested in the use of displacement, but i knew there were some issues to be fixed (instancing not allowed, plane surfaces not displaceable...): is there a version which fixed this? Did i miss it?
Posted: Wed Jul 02, 2008 1:47 am
by BbB
I think it's a great image. Floor, vases, wall, everything looks good if you ask me.
Posted: Wed Jul 02, 2008 2:00 am
by Pinko5
Nice work Pibuz as usual!!!
I like the floor in particular...
Luca. ;)
Posted: Wed Jul 02, 2008 2:51 am
by Borgleader
Pinko5 wrote:Nice work Pibuz as usual!!!
Luca. ;)
Exactly what I was going to say!! :)
Posted: Wed Jul 02, 2008 10:09 am
by Kram1032
Very nice composition :)
I'd like to see displacement on the wall and maybe on the floor :)
Posted: Wed Jul 02, 2008 7:17 pm
by Pibuz
Ok, guys: tried another POV, and another workaround for the floor tiles, sadly without any good result.. I followed Kwisten's suggestion of making a two-points perspective, and i must say he was right. So here's the result.
Posted: Wed Jul 02, 2008 7:52 pm
by BbB
A really nice piece! Are the vases pure phong? Can you describe your lighting rig?
Posted: Wed Jul 02, 2008 8:36 pm
by Pibuz
Hi BbB! Thanks a lot really: i'm a big fan of yours, so hearing a compliment from you is quite satisfying!
So: both vases are pure phong, with very very subtle bump; each vase has a slight different IOR and exponent, to achieve a minor variation; the light sources are simply a big emitter (the one behind the curtain) and two IES lights over the vases. Done. Pretty simple, indeed..
Posted: Wed Jul 02, 2008 8:41 pm
by BbB
Simple but effective. Would sit perfectly well in any decoration magazine.
Posted: Wed Jul 02, 2008 9:09 pm
by rgigante
Yes.. really effective setup.
Very interesting image PIbuz.
Thanks for sharing!
Riccardo.
Posted: Wed Jul 02, 2008 9:56 pm
by kwistenbiebel
Nice and pure!
