Kscore's Render Area
- arc en ciel
Re: Kscore's Render Area
but it's a nice picture anyway
- pixie
The overall look seems a bit flat, I don't know if it has to do with the tone mapping, look at chairs for example they seem to lack volumetry in the brown side.
@arc en ciel: Yes, that is caused from the light of the lamp.
@pixie: I think the flat look is caused from "clamp contribution" wich was set to "1". Wich eliminates the hotpixels and renders a lot fater, but this time it was set to low I think.
- arc en ciel
in the database there is a letchee material write in ISL by Galinette.
working well in all mode !
https://indigorenderer.com/materials/materials/1138
there is ISL code in the color channel and the bump channel
for change size of cells : tweak this value line 6 : )*35.
it will be necessary to change this same value in the code of "bump"
for change color : tweak values at the last line : vec3(0.78,0.70,0.25), vec3(0.78,0.26,0.24)
wow, great that there is a material of this in the database. Will be fun to try that out! Thanks for that!
Hey Guys, I worked on a personal project in my free time the last days. I wanted to try to work and improve my skills with an exterior with Indigo. You all know the farnsworth house by mies van der rohe? I am sure you know. I have worked in this scene with the sun light system and it worked pretty good for my taste. No HDRI was needed. Maybe I will do different lighting moods of this shot.
excellent jobs! waiting for the results with other types of lighting farnsworth house! Congratulations
Users browsing this forum: Ahrefs [Bot] and 41 guests
