Hi guys.
I just finished my lessons about Indigo-SkIndigo, and in one of the final tests one thing ame up.
I couldn't explain why, so here I am with my question.
The exact same scene was given to all the students, I report here a comparison between two results to show the difference and point out the question.
Like I said, the base scene is the same (during the lessons we modeled a detailed Barcelona Pavillion), exceptede a little variation for the water plane, which was randomly created with a SU plugin.
The first render was computed on a:
core2duo T5800 2GHz ram 2GB
and reached 312 s/px before the desired halt time (30mins)
The second render was computed on a quite older:
pentium centrino 2GHz ram 1GB
and reached 365 s/px in the same amount of time!
This sounded a little weird, if I might say. I couldn' explain why a slower processor could reach a higher SPP value. I've always thought to the SPP value as an objective parameter to determine the quality of renders in terms of noise: an image with 15000 s/px is more noise-free if compared to a 4000 s/px.
I know that sometimes different mats and geometry can make the real difference, but in this case the scene was exactly the same: same model, same scene setup, same materials (all diffuse), same lights, same environment...
Another strange thing is that the same scene looks more noise-free in the image with less s/px.
Can someone explain why this happens?
Thank you a lot!
understanding SPP
Re: understanding SPP
Maybe the faster cpu rendered on 1 core.
Or 1 core was under some nasty program like nero scout (if not disabled).
Checked while running.
No strange or leech programs running in the background, and the faster notebook was actually using the 2 cores, while the centrino the only core it has..
I did not encounter this when I did the renders for the GH house archviz challenge. (Or I may not have noticed it) I used a core2quad @2.3 ghz w/ 3gb ram and a core2duo @2.0 w/ 1gb ram to render several images which I merged later. Renders on the core2duo took twice as long to finish as those from the core2quad. I set the rendering to stop at 2000spp.
Can it be virus, or the cpu really is faster than the dual core, cant find benchmarks of centrino product line.
There are new Centrino 2 cpu's http://www.intel.com/products/centrino/
If possible, run another test with some benchmark
http://www.passmark.com/products/pt.htm
Or simple file compression benchmark, multi photo batch processing benchmark.
The noiser scene seems to have a surface leak for the water, light might enter there and bounce below the water surface a lot (for no visible result but ressources waste).
Even if it's not a geometry leak, it's a detail to dig.
edit: make sure that both scenes use the same mesh and displacement settings for the water surface.
Users browsing this forum: No registered users and 46 guests
