Page 1 of 1
Indigobench select gpu via command line
Posted: Tue Feb 13, 2018 5:43 am
by helloworld123
So I am trying to run indigobench on my macbook pro via the command line, but I only want it to run on the AMD GPU and not the intel integrated one. I tried the --gpuonly flag but it runs on both the GPUs on your computer (AMD and intel GPU). Is there any way to specify which GPU to run the benchmark on?
Re: Indigobench select gpu via command line
Posted: Fri Feb 16, 2018 2:13 am
by fused
currently that isn't possible. It could be added at some point, I guess. I put a feature request into the tracker.
Posted: Sat Feb 17, 2018 3:30 am
by helloworld123
If I want to add this feature in myself, how exactly would I go about doing that?
Posted: Thu Feb 22, 2018 4:31 am
by helloworld123
fused wrote: ↑Fri Feb 16, 2018 2:13 am
Wait, is Indigobench/Indigo Renderer even an open source project? That is why I asked if I can add the feature myself.
Posted: Thu Feb 22, 2018 4:50 am
by Oscar J
No, it's not.
Posted: Thu Feb 22, 2018 9:45 am
by helloworld123
I have a question regarding how the --settings flag works. I have a custom settings.xml file where the only device under the tag <selected_opencl_devices> is my AMD GPU, but when I run the command line pointing the --settings flag to that settings.xml file, it still runs indigobench on my intel GPU and the AMD GPU. Here is my command:
/Indigobench/Indigo\ Benchmark.app/Contents/MacOS/indigo_benchmark --settings "/path/to/file/settings.xml" --silent --scenes "supercar" --gpuonly
Here is my settings.xml file:
<settings>
<use_network_manager>false</use_network_manager>
<use_network_floating_licence>false</use_network_floating_licence>
<network_manager_hostname><![CDATA[localhost]]></network_manager_hostname>
<do_master_search_broadcast>true</do_master_search_broadcast>
<use_custom_cache_directory_path>false</use_custom_cache_directory_path>
<cache_directory_path><![CDATA[]]></cache_directory_path>
<use_custom_render_directory_path>false</use_custom_render_directory_path>
<render_directory_path><![CDATA[]]></render_directory_path>
<allow_gpu_as_slave>true</allow_gpu_as_slave>
<png_bit_depth>8</png_bit_depth>
<jpeg_image_quality>95</jpeg_image_quality>
<exr_bit_depth>32</exr_bit_depth>
<exr_compression_method><![CDATA[PIZ]]></exr_compression_method>
<use_online_license>false</use_online_license>
<online_license_user><![CDATA[]]></online_license_user>
<device>
<device_name><![CDATA[AMD Radeon Pro 460 Compute Engine]]></device_name>
<vendor_name><![CDATA[Apple]]></vendor_name>
<id>0</id>
</device>
</selected_opencl_devices>
</settings>
Posted: Fri Feb 23, 2018 3:51 am
by fused
--settings works differently, it expects the settings as xml, not a path to a settings file. For example: --settings "<width>1920</width><height>1080</height>"
The benchmark currently ignores the "selected_opencl_devices" setting. It should also be noted that not all settings can be overridden (render mode, for example). Also, overriding settings will make it impossible to submit the results to the database.
Posted: Mon Feb 04, 2019 9:02 pm
by nkvyas
Is there any update on this feature? When can we expect the new version later than 4.0.64?
