Invisible to camera - multiple select
Posted: Wed May 13, 2015 3:00 am
Is there a way to select multiple objects to be invisible to camera within Indigo at once?
I'm doing an isometric view of an office layout and I need all the lighting to cast as if you were inside the room. I've set my lights as blocks and clicking each one individually within Indigo and making it invisible to camera works fine, just the result I need - but I have around 80 lights and its proving to be incredibly laborious selecting each one individually and ticking the checkbox.
Is there a way to select all the lights in one go with Pick object? I've tried incorporating them all as a single block in Sketchup hoping I could just pick that block object and get the lot, but that didn't work.
Indigo 3.6.20 if that has any bearing.
Cheers
Cheers
