Environment Map with 'add sun'
Come here for help & support.
3 posts • Page 1 of 1
sking
Post by sking » Mon Aug 18, 2014 10:49 pm
Hi All,
If i try to use an environment map and tick the box 'add sun' i get this error when render:
An error occurred while SkIndigo was exporting the scene.
SkIndigo version: 3.6.28.3
SketchUp version: 14.1.1282
Ruby platform: i386-mingw32
Error during processing: undefined local variable or method `used_layers_array' for #<IndigoExporter:0x11d872a0>
C:/Users/sk/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:10019:in `export_environment'
C:/Users/sk/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:955:in `export'
C:/Users/sk/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:11606:in `block in <top (required)>'
-e:1:in `call'
Not sure if im doing anything wrong with settings? i have used this before with indigo fine.
Any help would be greatly appreciated,
Si
Re: Environment Map with 'add sun'
Post by Zom-B » Mon Aug 18, 2014 10:55 pm
If you have issues, the first thing to do is to bring your exporter and renderer up to date mate :wink:
http://www.indigorenderer.com/forum/vie ... =1&t=13177
http://www.indigorenderer.com/forum/vie ... 17&t=13122
There is a good chance that a problem was already fixed...
sking
Post by sking » Mon Aug 18, 2014 11:09 pm
Thanks Zom-B....yeah you were right, i thought i was up to date but my exporter wasn't :I
Thanks again!
