Params lost after translation
Come here for help & support.
3 posts • Page 1 of 1
Post by CTZn » Thu Jun 20, 2013 10:15 pm
MtI is not successful anymore in passing params to Indigo but I'm totally missing the point, the XML output looks correct and the feature was working recently.
Below MtI's output from the IGS. Indigo is missing the params and raises the related ISL error.
<medium>
	<name>indigoMedium1</name>
	<precedence>10</precedence>
	<basic>
		<ior>1.330000043</ior>
		<absorption_coefficient>
			<constant>
				<rgb>
					<rgb>0.02247653902 0.02247653902 0.02247653902</rgb>
					<gamma>2.200000048</gamma>
				</rgb>
			</constant>
		</absorption_coefficient>
		<subsurface_scattering>
		<scattering_coefficient>
			<!-- indigoText1 -->
			<shader>
			<param>
				<real>
					<name>Density</name>
					<description>Density</description>
					<min>0</min>
					<max>250</max>
					<value>75</value>
				</real>
			</param>
			<param>
				<real>
					<name>HeightRatio</name>
					<description>HeightRatio</description>
					<min>0</min>
					<max>50</max>
					<value>16</value>
				</real>
			</param>
			<param>
				<real>
					<name>GlobalScale</name>
					<description>GlobalScale</description>
					<min>0</min>
					<max>50</max>
					<value>0.5</value>
				</real>
			</param>
				<wavelength_dependent>false</wavelength_dependent>
				<shader>
<![CDATA[def eval(vec3 pos) real:
fbm01(
	vec3(
		pos.x,
		pos.y * paramHeightRatio(),
		pos.z
	) * paramGlobalScale(),
	8
* paramDensity()]]>
				</shader>
			</shader>
		</scattering_coefficient>
			<phase_function>
				<uniform/>
			</phase_function>
		</subsurface_scattering>
	</basic>
</medium>
<material>
	<name>indigoShader2SG</name>
	<specular>
		<internal_medium_name>indigoMedium1</internal_medium_name>
	</specular>
</material>
It must be some stupid mistake I made ?
Re: Params lost after translation
Post by OnoSendai » Fri Jun 21, 2013 12:22 am
Shader params don't work properly for volume parameters currently. Am looking at fixing.
Post by CTZn » Fri Jun 21, 2013 1:29 am
Ah alright, thank you.
On a side note, could the phase function be a shader ?
Users browsing this forum: No registered users and 114 guests
