Page 1 of 1
Exit Portal Material doubt
Posted: Wed Aug 25, 2010 7:28 am
by gmaisg
Hi, I have a doubt. Lets say I have a render from inside a house (interior scene) and have some big glass windows, do I have to create a plane with a EXIT PORTAL material covering the hole of the window? What I want is to have the glass material (the effect) in the window but with the light coming from outside. Thanks in advance.
:D
Re: Exit Portal Material doubt
Posted: Wed Aug 25, 2010 7:33 am
by Borgleader
What you can do is create a plane behind your glass with the exit portal material and make sure it's normal is facing the camera. It should in theory let light in, but not out.
Also make sure your glass object has volume :)
Posted: Wed Aug 25, 2010 8:04 am
by gmaisg
Hi, thanks for the rapid reply. I will try it and was what I was thinking in doing.
besta regards
:D
Posted: Tue Aug 31, 2010 7:49 pm
by Pibuz
If not extremely necessary, I'd suggest you not to have thick glass, to avoid longer render times.
For me Thin Glass does the job most of the times. 8)
Posted: Tue Aug 31, 2010 10:59 pm
by gmaisg
Ok, thanks for the advice. I will do that.
Best regards
:D
Posted: Wed Sep 01, 2010 2:43 am
by Godzilla
Posted: Wed Sep 01, 2010 2:58 am
by Pibuz
..isn't it thin glass?
Posted: Wed Sep 01, 2010 3:05 am
by gmaisg
Well, that's great. Various setups, depending the speed that I will want in my renders, thanks for all of you, very usefull.
best regards :D
