Page 1 of 1
Stones and Water.
Posted: Thu Mar 26, 2009 6:54 am
by kikeonline
Sup Guys!!!
I need Indigo's masters help.
How can I make those Stone more bumpy without displacement? They look very flat to me (on the rendered image)
Posted: Thu Mar 26, 2009 10:11 am
by Borgleader
Have you tried increasing the "b" value?
Posted: Thu Mar 26, 2009 11:53 am
by CTZn
Yes, did you evaluate the bump without a textured albedo first ?
What's the real limitation for not using displacement in this scene ?
Posted: Thu Mar 26, 2009 8:57 pm
by SmartDen
set the bump gamma value to 2.2
Posted: Fri Mar 27, 2009 5:50 am
by Jambert
water material is great
Posted: Fri Mar 27, 2009 9:41 am
by Psychotron80
Jambert wrote:water material is great
yep! can you post material settings, please?
Posted: Fri Mar 27, 2009 9:54 am
by Stur
May I ask why you don't want to use displacement ?
Bumpmaps always look flat when not seen from straight angles.
Posted: Fri Mar 27, 2009 10:07 am
by Borgleader
Stur wrote:May I ask why you don't want to use displacement ?
Indeed because bump mapping is just applying a a shadow map on top of the mesh to simulate the shadows. so the less perpendicular youre viewing angle is from the mesh surface, the "faker" it looks.
Posted: Fri Mar 27, 2009 11:04 am
by CTZn
The first part of your sentence is incorrect Borgleader, unlike the second
Differences in shading with bump occurs because it is perturbing the normal to the surface, effectively changing it's local orientation to the renderer and thus the outgoing direction of light after it interacted with the material, it's not just perturbing albedo (not at all in fact).
What's the height of the walls above the water surface Kike ? 1 seems a strong value for bump but am not a blender user, am I missing something ?
Posted: Sun Mar 29, 2009 6:33 pm
by kikeonline
Thanks a lot for the suggestion, I will try them all.
I'm still learning displacement on blender and indigo.
see you guys later
Posted: Mon Mar 30, 2009 8:55 am
by sandsturm3d
I hope some self promotion is allowed: did you consult the wiki?
http://www.indigorenderer.com/joomla/co ... placement/
Best regards,
Martin
Posted: Mon Mar 30, 2009 9:27 am
by Borgleader
I think it would be pretty illogical to bust you for promoting another part of the indigo website
