Page 1 of 2
My kitchen
Posted: Tue Nov 18, 2008 9:39 pm
by delle
Hi, this is my kitchen...
Bye
Delle
Posted: Tue Nov 18, 2008 10:43 pm
by Pibuz
Hi Delle!
Interesting work! Congratulations!
I think the radiator area is really GREAT, and the cooking plane good enough.
I'd rather work a little more on the shaders of the furniture, it all seems no reflective at all, and that is not real..
The objects you used, instead, are really good!
Overall, a nice work for me!
Posted: Tue Nov 18, 2008 11:47 pm
by Photoguy
Cute kitchen!
Although someone left the door open, and some fireflys got in. :wink:
Posted: Wed Nov 19, 2008 10:36 am
by ROUBAL
Nice render ! Well done.
Posted: Thu Nov 20, 2008 2:08 am
by delle
HI, here is another rendering in progress with some changes...
Delle
Posted: Thu Nov 20, 2008 2:38 am
by delle
Added a background with Photoshop... :wink:
Delle
Posted: Thu Nov 20, 2008 2:57 am
by suvakas
Hmm..so full of fireflies.
What is your Super Sample Factor parameter set to?
Posted: Thu Nov 20, 2008 3:06 am
by delle
I use default settings except these ones...
  <renderer_settings>
    <width>1280</width>
    <height>960</height>
    <aperture_diffraction>false</aperture_diffraction>
    <post_process_diffraction>false</post_process_diffraction>
  </renderer_settings>
Bye
Delle
Posted: Thu Nov 20, 2008 5:51 am
by seregost
Good work, i like it, but I think you haven't this view from your kitchen :lol:
Pay attention to alpha channel :D
Posted: Thu Nov 20, 2008 6:47 am
by rgigante
Hey Delle,
are your light source covered with specular transparent materials? This could be the source of the fireflies... imho
R.
Posted: Thu Nov 20, 2008 9:18 pm
by delle
No, I've removed glasses from the windows to avoid that.... :wink:
Delle
Posted: Thu Nov 20, 2008 9:58 pm
by Zom-B
Hey Delle, here just my 2 cent:
Do U use Exit Portals for the balcony? This should speed up the scene (less fireflies!)
The metal thing on the balcony seems to e an image with alpha map.... the white border isn't very nice, take care not to use step blend option if you alpha map is not pure black/white...
Did you used the render alpha foreground option of Indigo to get a mask for the sky? If not, give it a try, it renders super fast ;-)
Posted: Thu Nov 20, 2008 10:36 pm
by delle
No, if I use exit portals the terrace disappear :wink:
I've used the "Magic wand" tool of PSP 8 that's why there is the border...
Could you explain in detail?
P.S. Here is another version with the real background (Genoa - Italy)
Bye
Delle
Posted: Fri Nov 21, 2008 4:29 am
by Zom-B
He he.... nobody ever said that a Exit Portal has to be a simple 2D plane ;-)
Just make a box shaped Exit portal with no wall to your scene (normals facing inside!) so your terrace is stil infront of the Exit Portal!
Its slower than simple 2D plane, but should be still lot faster than without exit Portal!
just check out this link: http://www.indigorenderer.com/joomla/fo ... php?t=3479
Posted: Fri Nov 21, 2008 5:06 am
by delle
It causes a Crash to Indigo (v1.1.14)... :shock: :shock:
Here is a simple scene that causes the crash (IndigoCrash.igs)...
If I eliminate the line...
<render_foreground_alpha>true</render_foreground_alpha>
... it renders well (see picture im1227199955.png)
Bye
Delle[/quote]
