Page 1 of 3
Firs test... (interior)
Posted: Wed Nov 28, 2007 2:00 am
by Hasan
Hi , its my first render. But I can not succeed in clear render. What time is needed?
Regards.
Hasan
Posted: Wed Nov 28, 2007 2:11 am
by SmartDen
what are you using as lightsource? if sunlight, then try to use exitportals in your windows.
Posted: Wed Nov 28, 2007 2:13 am
by dougal2
give it a day
scenes usually start to look clean with upwards of 2000 - 3000 samples per pixel.
it varies a lot on the scene though, and will take longer than that to clear up some areas, especially where there are shadows or indirect lighting.
Posted: Wed Nov 28, 2007 2:15 am
by psor
Hi Hasan,
first --> welcome aboard, have a seat - drinks are in the fridge!
Looks promising already. Some quick questions for ya.
1. How is your scene lit?
2. Did you use any exit portals?
3. Whats your system spec (CPU/RAM/OS)?
edit: Darn, I'm to slow!
take care
psor
Posted: Wed Nov 28, 2007 2:22 am
by Hasan
SmartDen wrote:what are you using as lightsource? if sunlight, then try to use exitportals in your windows.
SmartDen, not sunligt. I use blackbody spectrum.
<background>
<spectrum>
<blackbody>
<temperature>5000</temperature>
<gain>1.0</gain>
</blackbody>
</spectrum>
</background>
Posted: Wed Nov 28, 2007 2:27 am
by Hasan
dougal2 wrote:give it a day
dougal2, thanks for your explanations...
Posted: Wed Nov 28, 2007 2:31 am
by SmartDen
for better results you should use sun light + exit portals
Posted: Wed Nov 28, 2007 2:37 am
by Hasan
psor wrote:Hi Hasan,
take care
psor
psor, thanks. I dont use exit portal. My system : 1 GB RAM, 1.7 GHz CPU
Posted: Wed Nov 28, 2007 2:42 am
by Kosmokrator
hhmmm u have problem with cpu power man......your scene will be need much time to clear even use exit portals.....
sug:buy new pc!
or have patience
Posted: Wed Nov 28, 2007 3:00 am
by SmartDen
Kosmokrator wrote:hhmmm u have problem with cpu power man......your scene will be need much time to clear even use exit portals.....
sug:buy new pc!
or have patience
not everybody can have such PC as you have
Posted: Wed Nov 28, 2007 3:05 am
by Kosmokrator
im not talk about supercomputers......some simple core 2 duo 4500 or 6550 will do incredible work with renderings......and is in general terms cheap....anyway i dont say buy new pc with irony!.....just for him i know how it is to wait ages to finish the rendering ,i have too, some ages before ,slow pc
Posted: Wed Nov 28, 2007 3:09 am
by Hasan
Kosmokrator thanks for the suggestion:)
I will try the exit portal...
Regards.
Hasan
Posted: Wed Nov 28, 2007 5:01 am
by Whaat
Looks like path tracing to me...maybe use MLT instead? Although using bidirectional path tracing with exit portals will work even better.
Posted: Thu Nov 29, 2007 9:38 am
by Hasan
Whaat, yes, I just learn Indigo. Ok, I changed Metropolis =False and I use Exit Portal. Now, it is fast and clear. The render is running, but the result is following at 30. minute (800x600):
Posted: Thu Nov 29, 2007 10:23 am
by Kram1032
Well, I'd say, Exit Portals where a good idea, but in this scene, I don't actually see too much direct light... SO, I bet, it's better to switch Metropolis on...
(you can easily see this, when looking at the carpet, which is noise-free, where the sun shines on it, but all the rest will stay relatively noisy...)
