thats so mothaphukin cool
Thank you, nice to know that Im not the only one
Here another object:
Playing with new animation retime feature in Max 2013 Rendered with Indigo.
http://www.youtube.com/watch?v=I9PgdY6DAIE
Sweet abstract, but I gotta beg you again to use radial+sharp filters!
(Model from alvis)
Hello,
Here's a first test of implemented normal maps in IndigoMax. Effect is a bit too subtle and needs some more investigation.
Cheers,
Cheers,
Canyons !
- canyons.pigm
- (882 Bytes) Downloaded 179 times
CTZn wrote:Canyons !
A nice "simple render"
Oh God! That's wonderful!
..Always loved displacement
The colour distribution is shader or there's a base texture? Could you show us the maps, even little, just to have an idea of what your workflow has been
- ninopiamonte
Awesome!
'T can be a wallpaper with more details.
The beauty Cotty is that the displacement shader is even simpler than the albedo shader: no maps used Pibuz it's all ISL !
The displacement method is basically a noise wich uses itself for it's U and V placement. By the way I should be able to add directional (wind) erosion. The albedo mixes a bit of the displacement (lower is darker) with randomized horizontal layers.
The material is attached above; I applied it on a 1km square plane. The subdivision is view dependent, there's no way my computer can handle more polys, Nino
Virtual landscapes are pretty exciting I recon !
Super-awesome work CTZn!
It looks like you're using the normal Indigo sun+sky model (as opposed to the full atmospheric scattering simulation), is that correct?
It would be nice to see with the full simulation.
It certainly would look awesome ! I'll do that at some point Nick, meanwhile there is the scene for the courageous rigs; they'll need 8 Gigs equiped, more or less.
- canyons.pigs
- manypolys
- (2.85 KiB) Downloaded 212 times
Oh, and something else I add in mind was to explore the Indigo scattering capabilities to add rocks and boulders at the ground level.
I'll create a thread on virtual landscapes.
Yup, that's what the scattering stuff is for!CTZn wrote:Oh, and something else I add in mind was to explore the Indigo scattering capabilities to add rocks and boulders at the ground level.
I think there are problems with scattering and quads currently, so I don't think it will work currently.
